86 fuel pump runs nonstop
Old Aug 19, 2013 | 12:43 AM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default 86 fuel pump runs nonstop
I have an issue with the fuel pump not stopping after key is off. I unplugged the fuel relay and the pump kept going. Did I get the wrong relay? Theres two relays that I know of in the engine bay and I disconnected both (one near the wiper motor and one on the drivers side wheel arch) and the pump still ran. I then disconnected the oil pressure switch and it went off. I replaced the switch and the pump still ran continuously. I then pulled the plug off the oil pressure switch just a tad and the pump went off. I put the key to the on position and the pump cycled on for a few seconds and it went off. If I put the plug on the switch with slight pressure (all the way on and then a little slight pressure) the pump starts to run again. Do I have bad oil pressure plug? If so, where would I get another one or work around?
Old Aug 19, 2013 | 12:53 AM
vetteoz's Avatar
vetteoz
Originally Posted by PMARTINEZ92126
I then pulled the plug off the oil pressure switch and the pump went off.
Yes
Hook the relay back up and leave the OP switch disconnected until you get a new one.
Pump will run from the relay only , the OP switch is there as a backup should the relay fail
Old Aug 19, 2013 | 12:57 AM
vetteoz's Avatar
vetteoz
Nothing special , just a pressure switch used on many GM cars and truck s,
Check out your local part shoppe
see
http://forums.corvetteforum.com/1572642680-post7.html
To 86 fuel pump runs nonstop
