headlight rotation repair?
Old Aug 20, 2013 | 08:18 AM
DucXL's Avatar
DucXL
Default headlight rotation repair?
Since i bought this older '87 (have an '89 too) last month i noticed the RH has been lazy and slower to open than the LH.Last nite it wouldn't close w/o a little help.DID a search w/o success here.Have been told there are some little pellets that can be replaced to solve this.Just thought i'd try to gain some insight to this problem.Can someone please assist in diagnosis?
Old Aug 20, 2013 | 08:27 AM
tbirdsps's Avatar
tbirdsps
http://forums.corvetteforum.com/c4-t...air-w-pic.html
Lots of info in the forums. Check the stickys. I did my 90 a couple of weeks ago. Really not very difficult.
There's so much info here in the forums it will make your head spin....
Old Aug 20, 2013 | 11:53 AM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
If you have the original motors, you do not have the bushings.. Here's a write up for the 84-87..
http://forums.corvetteforum.com/c4-t...placement.html
Old Aug 20, 2013 | 01:13 PM
DucXL's Avatar
DucXL
The local supply house Corvette's & Classics had the gear in stock for $25.I think i can install it in a few days.It still sorta works
Old Aug 20, 2013 | 04:17 PM
JMelton's Avatar
JMelton
Check to make sure you aren't missing any hardware on the motor mounts, or have a broken bracket.
My 96 had a lazy eye that would do that occasionally.. Found the long bolt was missing when I first got the car, and had to replace the bracket later on because it broke after having been weakened by the missing bolt.
To headlight rotation repair?
