L98 single plane elbow
Old Aug 23, 2013 | 07:28 AM
VeTTeMaNC486's Avatar
VeTTeMaNC486
Default L98 single plane elbow
I am planning on putting a victor JR single plane on my 86 and I am wondering if anyone knows if the Nitrous Outlet elbow will fit under the stock hood. Are there any other options for fitting under the stock hood?
Old Aug 23, 2013 | 08:02 AM
C409's Avatar
C409
..... How about this ? ... Allows ALL the OEM hook-ups ... minimizes fabrication ... and fits under the C4 hood ... see my post in the parts for sale section for more pics and details ... FWIW ... I tried the Victor E and the biggest problem was that the front water crossover for the thermostat is too high for an OEM-style throttle body ............
Old Aug 23, 2013 | 09:42 AM
leesvet's Avatar
leesvet
why not go the distance and just slice out a few inches of plenum immediately behind the TB mount plate and move the TB mount back to make the "upper" plenum square so the things acts more like a continuation of the base plate plenum?
That would (looks like anyway) get some working room for the T-stat neck of some sort...
Just a thought.
Old Aug 23, 2013 | 12:42 PM
VeTTeMaNC486
I saw that and read about it. I am not concerned about having factory hook up for anything as I currently have a miniram and everything is changed anyways. The only concern is location/configuration of throttle cable bracket, which on the phone said they could put it where ever it was needed. After talking on the phone with them I believe it is short enough to fit under the hood, but I am worried that the TB might not be angled downward enough to clear. On the victor e intake; I looked at that and I will probably go with a remote thermostat housing. I also liked the pic I saw on here of the guy with a tube welded to the front of the coolant crossover with the tstat forward facing. Also, although I do have access to a tig welder, I am not comfortable welding aluminum for the fabrication that would be necessary for the solution that you posted. I am more of a plug and play kinda guy... (sounds dirty ). I have seen several sheet metal elbows around here but not where people got them from. (Maybe they made them???)
Old Aug 23, 2013 | 02:42 PM
C409's Avatar
C409
Originally Posted by leesvet
409...
Just a thought.
..... That would be fine but there is still the issue of clearance above the fuel rails for the IAC and throttle linkage , especially when combined with the TV cable access for A/T cars ... besides , most everyone has access to a TPI plenum that's cheap if not free ... and the less hacking and welding that's done , the more likely it will fit up to all your original necessities like air intake plumbing , vacuum hoses , and throttle linkage , TV cable ( no need to revisit high school geometry ) and even Cruise control ... very plug n play ....
Old Aug 24, 2013 | 12:57 AM
vetteoz's Avatar
vetteoz
To L98 single plane elbow
