Circuit#450(I think) which is pins 9&12 on the ECU(white) connector might go to?(they're sposed to be grounded...and I was wondering if folks know where they might tie into ground..
and part two of the question:
I have two black ground wires that are connected to ground via eyelets on a bolt in the passenger side well, on the right side.(just under the plastic leg kick panel)
Any chance these two wires are supposed to be the #9 # 12 wires off the ECU plug mentioned above?
What year Corvette are we talking about here? Straight shift or auto? Any mods? I have learned that this site is a very good place for info, but most, if not all of the Guru's need a starting point. Do you have a Factory Service Manual? If not, locate one.
which is pins 9&12 on the ECU connector might go to?(they're sposed to be grounded...and I was wondering if folks know where they might tie into ground..
ECM grounds usually terminate at the large bolt on the engine block above the oil filter
well well, that was a brilliant one mate!
I actually found a black wire, CAPPED OFF nearby the oil fill...
It read short to pins 6 & 12 on ECU white conn!
Why it was capped off, and also how that injector ever fired I dunno..
But I now have power to the fwd injector.
Thanks!
R
