Fuel Pressure
Old Aug 25, 2013 | 08:51 PM
shamdave's Avatar
shamdave
Default Fuel Pressure
I have a 1985 I have new Bosh 3 injectors newer fuel pump, new fuel sending unit replaced the fuel filter last year.
It was running fine. a few days ago I had a fuel gauge issue where the float was hung up @ 1/4 tank. I pulled the fuel sending unit re adjusted it and it was fine.
Today it stalled a couple times when it was @ idle making a turn and seemed to stumble a few times under acceleration. I checked the Fuel pressure @ the rail and it goes to 40 and drops quickly to 0 with the battery on.
When it starts it idles @ 38-40 but drops to around 30 when i accelerate the engine.
Please ideas are needed.
Old Aug 25, 2013 | 09:06 PM
vetteoz's Avatar
vetteoz
What does it show with the vac line disconnected and engine running
Old Aug 25, 2013 | 09:36 PM
SeeFourSix's Avatar
SeeFourSix
fuel pressure regulator?
Old Aug 25, 2013 | 09:41 PM
shamdave's Avatar
shamdave
Fuel presure regulator is about 3 years old. I should also mention i kinda smell gas, and it has a new EGR valve and cyilnoid.
I did not disconnect the Fuel pressure regualtor with the vaccum line what will that do?
Old Aug 25, 2013 | 09:48 PM
gerardvg's Avatar
gerardvg
Check your tank has the container still plastic welded in the middle of the tank, the fuel pump sits inside this to prevent fuel starvation when around 1/4 of a tank is left when accelerating and cornering.
The 85 has 24lb injectors standard so have a lower fuel pressure, my 85 was 30-32 psi but some forum members have said they have around 38-40 psi.. TPI's love more fuel 45 psi is a sweet spot but can make idle rich and fail emissions testing however improved mid range and top end performance.
Do you have a standard fuel pressure regulator or is it and adjustable type (with screw for adjustment on top)
I never noticed any stumbling under acceleration at 30 psi with the TPI in standard form, she always accelerated hard breaking traction as the rpm and torque rise.
You may need to check for fouled plugs or bad ignition leads, if the idle screw has been tampered with you may need to set the base idle again.
Check your TPS throttle position sensor (top and middle wires with multimeter and set 0.54 volts at idle or ignition on and check it rises steadilly to 4.5 volts full throttle (no need to run engine ignition on is all that is needed)
Reset the ecm there is a cable near the battery to reset codes as the ecm will try to counteract things and get in a knot.
Old Aug 26, 2013 | 01:12 AM
Cliff Harris's Avatar
Cliff Harris
The vacuum controls the fuel pressure. When you go to WOT the vacuum drops to almost zero, which raises the fuel pressure. The vacuum at idle is very high, which gives you minimum fuel pressure.
Sometimes the fuel pressure regulator diaphragm ruptures or develops a hole. If that happens the vacuum line will fill up with fuel and it will end up in the plenum. Usually when that happens the engine will run rich because of the extra fuel. In extreme cases you'll get a fire (happened to me -- you can see where the fuel pressure blew the vacuum line off the FPR. Fuel sprayed all over the engine. The white powder is from the fire extinguisher. When I took off the plenum fuel poured out of it.):
Old Aug 26, 2013 | 03:04 PM
aklim's Avatar
aklim
If you take off the hose and you smell gas, you have a problem with the regulator diaphragm being torn or leaking.
aklim's Avatar
aklim
Lucky you. Glad we are reading your post instead of your obituary.
Old Aug 26, 2013 | 04:47 PM
C409's Avatar
C409
..... You have to keep over 1/2 tank of fuel in just about any C4 for adequate fuel supply to the pump during maneuvers and brisk acceleration ... otherwise the fuel sloshes , the pump sucks air and the engine stumbles ........................
Old Aug 26, 2013 | 07:04 PM
aklim's Avatar
aklim
Haven't seen that in the few cars on the auto cross runs. They run with a quarter tank for weight savings. Have to try it out myself since I always run till empty before filling up.
Old Aug 27, 2013 | 03:43 AM
Cliff Harris
I have only had that happen ONCE since I got my car in 1985. I was on a freeway cloverleaf and going pretty fast and it stumbled. I autocrossed this car from 1986 until 2002 and never had that happen.
Old Aug 28, 2013 | 06:23 AM
blackozvet's Avatar
blackozvet
Ive got exactly the same issue as you shamdave, I know its a leaking injector in mine coz the reg diaphragm and fuel pump are new,
there are 3 major things that will cause the fast pressure leakdown, the pump not holding pressure, the diaphragm not holding pressure or the injectors not holding pressure,
one trick i tried was to undo the out fuel line at the tank and got my brother to put pressure into the fuel system with a compressed air gun while i listened at the engine,
well it worked, i could hear the injector leaking, until he squeezed a fraction too hard and it went to 65 psi, then the leak stopped ! seems that putting in more than 44 psi that the reg was set at closed up the leaking injector/s.
unfortunately it didnt fix the problem coz when i started it and ran it, stopped the engine, the fuel pressure dropped of quickly again, so it looks like the leaking injector/s pintle valve has jammed open again when it started operating.
anyway have ordered a new set of bosch 3 30lb injectors from Jon today (its only money !)
Old Aug 28, 2013 | 08:43 PM
shamdave's Avatar
shamdave
I just got my new bosch 3 injectors from John, I would be very surprised if it was the injectors. may be time for a consult from Danny Popp
Old Aug 28, 2013 | 09:00 PM
hemivett's Avatar
hemivett
New doesn't always mean good. In 45yrs of working on cars, I've gotten lots of bad parts right out of the box, and its not uncommon for fuel related parts to fail early if the aren't properly assembled. h
Old Sep 1, 2013 | 09:59 AM
shamdave's Avatar
shamdave
Ok so I checked the Fuel pressure regulator.
It runs about 46-48 with out the vacuum line and i do not smell gas, so im lead back to the fuel sending unit and pump.
Also it seems to stall more when its cold
Old Sep 1, 2013 | 11:50 AM
aklim's Avatar
aklim
Does it hold pressure after shutdown? For how long? What is the drop off like? Check it after 1 hour and 2 hours.
Old Sep 1, 2013 | 11:58 AM
shamdave's Avatar
shamdave
It drops very fast it drops to 0 within 30-60 seconds
I also failed to mention i eliminated the 9th injector
To Fuel Pressure
Old Sep 1, 2013 | 12:07 PM
aklim's Avatar
aklim
Something is leaking. Not sure if it is the regulator or injectors. Clamp off the return line in the fuel fill area and see if it drops.
Without the 9th injector, you will need ECM changes to enrich the fuel spray if I am reading those that have done it correctly, Also it could be the fuel pressure drop.
Old Sep 1, 2013 | 12:34 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
There is a check valve in pump. If it is not sealing, you will lose pressure fast, after pump is off.
Also,there is a pulsator between pump and supply line in tank. That can also leak and cause a quick loss in pressure.
Old Sep 2, 2013 | 10:13 AM
shamdave's Avatar
shamdave
Also,there is a pulsator between pump and supply line in tank. That can also leak and cause a quick loss in pressure.[/QUOTE]
I eliminated that and replaced it with a hose and clamps
which one is the return line? Looking at the FSU standing at the back of the car of the 2 lines on the right the top or bottom?
