Fluid Change
Old Jul 1, 2002 | 10:58 AM
93aqua's Avatar
93aqua
Default Fluid Change
I’m changing all my fluids. What is the recommendation?
Amsoil. 10-30?
Differential fluid? What kind and numbers I need to look for.
Transmission fluid redline syntec, any specific kind for the LT1?
Old Jul 1, 2002 | 12:04 PM
silver & red CE's Avatar
silver & red CE
Default Re: Fluid Change (93aqua)
I just did this. Be sure to flush your brake fluid at least every two years. Here's what I used:
Motor oil Mobil1 10W-30
trans lube (manual) Castrol Synthetic 10W-60
trans lube (auto) Mobil1
rear diff Mobil1
suspension lube points Mobil1
brake fluid Super Blue
clutch fluid GM
power steering Valvoline Synthetic
radiator Dex-Cool, no pellets
Eric
Old Jul 1, 2002 | 01:08 PM
Rob90's Avatar
Rob90
Default Re: Fluid Change (silver & red CE)
That's whats in mine also
Old Jul 1, 2002 | 02:04 PM
PTz-92-LT1's Avatar
PTz-92-LT1
I flush my brake fluid every year. Here is a list of other fluids:
auto trans Mobil1
differential Mobil1
radiator Dex-Cool, Red Line Water Wetter, and GM pellets.
Have used Amsoil frequently.
Old Jul 1, 2002 | 04:32 PM
93 ragtop's Avatar
93 ragtop
Default Re: Fluid Change (PTz-92-LT1)
I think as long as you use a fluid that meets the corvette specs. you will be fine. I do have a question for the guys using the mobil 1 diff. fluid. Do you use a additive and what is your experiences with it?
Old Jul 1, 2002 | 04:39 PM
93aqua's Avatar
93aqua
Default Re: Fluid Change (Red 86 4+3)
what are the correct specs...i want to make sure i get all the right fluids, dont want to mess up my car at all.
Old Jul 1, 2002 | 05:44 PM
silver & red CE
I use one bottle of the GM friction modifier with every change. Not sure if it's required, some guys have reported it's not needed, it's such a pain to get to the fill plug, I figure I might as well.
The specs are in the owners manual and the factory service manual. All the lubes I used are factory approved.
Eric
Old Jul 1, 2002 | 06:48 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Stick with regular green anti-freeze for a pre-94 car, GM does not recommend DexCool for pre 94 vehicles. Do a search on this board and you can find the TSB on this subject.
I recently changed to GM "cold climate" power steering fluid. It's semi synthetic like the Valvoline. Did use Valvoline for one year with no problems, but rumor of sensitivity to some seals.
You never said if your car is a manual or automatic?
To Fluid Change
