Dead Vette
Old Sep 1, 2013 | 11:02 PM
ronexpofan's Avatar
ronexpofan
Default Dead Vette
So I had a week where I could not use my vette, an 87, and now it's dead like a door nail . Tried boosting and that did nothing. Probably simple to most more experienced than I, but tomorrow I shall check if there is power at the battery, but what could have gone wrong out of the blue? Starter? Alternator? Thanks all.
Old Sep 2, 2013 | 03:00 AM
Cliff Harris's Avatar
Cliff Harris
Sometimes batteries just die suddenly for no apparent reason.
I once stopped at a gas station on the way home from work and when I tried to restart the car it was completely dead. No dash lights or anything. The mechanic measured the battery and it showed 4 volts. Fortunately they sold batteries there...
If boosting doesn't work you could have a bad battery cable or connection. I had a battery leak acid into the battery cable and boosting did nothing. The battery was fine and a new cable fixed it.
Old Sep 2, 2013 | 08:06 AM
ronexpofan's Avatar
ronexpofan
Originally Posted by Cliff Harris
Sometimes batteries just die suddenly for no apparent reason. Thanks Cliff, much appreciated
Thanks a lot Cliff, supposedly a new battery but will check the voltage.
Old Sep 2, 2013 | 09:20 AM
ghoastrider1's Avatar
ghoastrider1
quick check is to try starting the car with the lights on. If the lights don't change at all,or stay very bright, it aint the battery.
Old Sep 2, 2013 | 09:23 AM
ronexpofan's Avatar
ronexpofan
Thanks, good plan, as soon as it stops pouring out. Happy labor day
Old Sep 2, 2013 | 09:29 AM
AirForceOne!'s Avatar
AirForceOne!
Mine did the same thing out of the blue, but it was the starter, but I had power to everything else!
Your battery shouldn't go completely dead after a week, unless it's a bad battery.
Like Cliff said, start with the battery cables first.
I keep mine on a battery tender when not in use!
Good luck!
Old Sep 2, 2013 | 09:49 AM
ronexpofan's Avatar
ronexpofan
Thanks all, love this forum
Old Sep 2, 2013 | 09:53 AM
ronexpofan's Avatar
ronexpofan
Good luck!
Thanks AF1
To Dead Vette
