Have fire/won't start
Old Sep 2, 2013 | 05:31 PM
wagontrainer's Avatar
wagontrainer
Default Have fire/won't start
Wasn't getting fire to the Spark plugs.Getting fire to the plugs but won't start now.This is on a 1988 Corvette TPI engine i just installed in my 1966 Nova.When i try to start it,appears to try to run for about 1 sec them act like not getting fuel.After it does this Number 8 Header tube feels warmer than the rest.But as i said it just runs briefly.This is all new to me so i am at a loss and don't know where to turn.Hoping someone on this site can shed light on this problem.
Old Sep 2, 2013 | 06:38 PM
AirForceOne!'s Avatar
AirForceOne!
Did you install the ECM when you installed the motor?
Old Sep 2, 2013 | 07:14 PM
vetteoz's Avatar
vetteoz
This is all new to me so i am at a loss and don't know where to turn..
Is the TPI computer from a 88 vette?
Have you had the tune on the chip modified to suit your retro fit TPI?
If not you need to get the fuel enable function (VATS ) on the tune changed so the injectors will spray fuel
Unlikely to have spark without a ECM
Old Sep 2, 2013 | 07:52 PM
wagontrainer
sure did.the engine and computer set up came out of a running driving 72vette
Old Sep 2, 2013 | 08:44 PM
vetteoz's Avatar
vetteoz
What it was previously in has little bearing on it now.
Assuming it was setup and running correctly in that car , you have something fundamentally wrong with your install.
No fuel ( you have checked that the pump is running and confirmed you have the correct fuel pressure at the engine 1st ????? )
= no injector pulse from the ECM so either a bad ICM in the dist not sending a signal to the ECM to pulse the injectors
See
http://www.thirdgen.org/techboard/po...560-post2.html
http://forums.corvetteforum.com/1562372000-post8.html
or
VATS (which disables the injectors ) is still enabled on the chip in the ECM and the previous owner had a external VATS input to satisfy
that requirement
read
http://www.thirdgen.org/vats_passkey_system
Old Sep 2, 2013 | 09:57 PM
wagontrainer
This might sound like a stupid question,but here goes.When i hooked up the fuel line i ran the 3/8"supply line to the 3/8" line coming from the Fuel rail but shouldn't the fuel supply go through the Pressure Regulator before going through the fuel rails?
Old Sep 2, 2013 | 10:01 PM
vetteoz's Avatar
vetteoz
Opposite to a carb fuel supply
The supply goes to fuel rail 1st ( to injectors ), then the regulator , then return line
The regulator holds the required pressure in the rail above the injectors.
if the other way around would have no pressure to the injectors as the fuel rails would be a open line back to the tank
Old Sep 2, 2013 | 10:32 PM
wagontrainer
Just my luck.Now i am back to square 1.Talked to the man that had the Engine before i did and he said all was well when he had it.I can believe him.Good Friend.The only changes made(1)I have new TPIS Harness (2)He had 4 Speed Manual I have 700r4(3)He had external Pump i have intank Pump.He had Original TPI setup i have TPI setup from Arkansas Polishing.Same ECM with Hypertech Chip that he used.
Old Sep 2, 2013 | 10:42 PM
wagontrainer
See
or
that requirement
read
I do have fuel pressure but unsure about how much PSI(Fuel Pump,Tank is from Tanks Inc.
I do have another Distributor i can try.
I assume VATS was removed as it is not showing when testing for Codes.
Old Sep 2, 2013 | 11:05 PM
vetteoz's Avatar
vetteoz
On that basis, do the ICM signal and injector power tests linked above
The injector fuses are good ?
Old Sep 3, 2013 | 09:21 AM
wagontrainer
Fisrt off i want to thank you for hanging in there with me on this.I have somewhat of a deadline as "Cruisin the Coast" in Mississippi is coming up October 6 and it won't be as much fun without a ride.
I will get a Noid light ordered today.Will do the ICM signal test hopefully today.Again thanks,Mark
Old Sep 3, 2013 | 11:14 AM
wagontrainer
See
or
that requirement
read
Talked to the Rep.at TPIS and he is 95% sure it is the VATS was not disabled in the Chip.Just as you said he feel the previous owner had an external VATS Input.Sending me the needed dumahiky to piggy back my Chip to bypass the VATS.Will let you know in a couple of days.Thanks,Mark
To Have fire/won't start
