Brake light help...getting pi$$ed at it
Just ground it and probe the wire you get a reading or it lights up if 12 volts are present. Electrical issues are not clogs they are either open or closed, there is no smoke that leaks out, a switch can short and no longer work mostly caused by a faulty contacts in the switch itself or ground issues.
If a switch "Shorts", by definition it passes current even when it is not supposed to do so, and the smoke remains in its containment vessel. If a switch, wire or other component loses continuity and it can no longer pass current from the supply (battery+ terminal) to the ground point (battery- terminal), then it is referred to as being "open". The development of this open state is triggered by the release of device smoke from the containment vessel. Similar to a tree falling in the forest, the smoke release occurs even if no one is there to witness the event.
The second source flows through a fuse that is only "hot" when the ignition switch is on. This source flows through the turn signal flasher and onward to the turn/hazard switch. When you actuate the turn signal function, current from the flasher is routed to the appropriate bulbs (front and rear, left or right). The circuit for the selected side is simultaneously removed from the supply line from the brake light switch and remains connected to the unselected side. That allows the unselected brake light to burn solid if the brake is depressed, and the selected side to continle flashing.
The third source coming into the hazard switch comes from a fuse that is always hot and passes through the hazard flasher and on into the turn/hazard switch. When the hazard switch is engaged, power from this source is routed to all four turn/brake filaments. To keep the switch design simple (and therefore cheaper and more dependable) the hazard portion of the switch does not isolate the power source coming from the brake light switch. That is why pressing the brake pedal with the hazards on makes all four lamps shine solid.
It's too bad the manufacturers don't print big thick books containing repair and troubleshooting information. You could just buy one, troubleshoot and fix your car and quit hating it. In fact, if there was a place on the internet where people advertised stuff they wanted to trade for money, you could go there and search and just maybe find such a book. In an ideal world, such a place would not allow the sale of any books with the words Haynes or Chiltons on the cover.
Bottom line, if all three functions are not working, I'd start by checking for the presence of voltage at the brake switch and both flashers. If power is absent from all three I'd look for problems at a common power source, such as a fuseable link. If power is present, I'd suspect a problem internal to the flash/hazard switch. All kidding aside, having a Factory Service Manual simplifies the troubleshooting process enormously, especially if the car is a "Project" with multiple problems to chase.
