Perplexed
Old Sep 10, 2013 | 09:07 AM
GATHOF@AOL.COM's Avatar
GATHOF@AOL.COM
Default Perplexed
The other day my 92 stopped running, go figure. It started normal, then started running like it was running on 4 cylinders. It had done this about three years ago with a clogged fuel filter. I changed that and it fixed the problem. This time it did not. I could not see any fuel out of the line (I cycled the key) or hear the pump run so I changed it, it was the orignal.
I do not not think it is the OPTI due to the way it died. Is there a reset for the fuel system? By the way the only code was for a OXY Sensor. Any other suggestions!
Thanks in advance!
Old Sep 10, 2013 | 11:14 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
So at this point, you've changed the fuel filter, the fuel pump, and it still won't start? Is that correct? If that is the case, what is missing: Spark or fuel?
Old Sep 10, 2013 | 12:59 PM
GATHOF@AOL.COM
Yes, Have not checked that , but I will. Does this check like the old cars just thru the spark plug wire?
Old Sep 10, 2013 | 03:54 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
That is correct.
Old Sep 10, 2013 | 05:52 PM
GATHOF@AOL.COM
I willl giive it a try and get back! Thanks
To Perplexed
