1986 cooling temp switch
Old Jul 2, 2002 | 07:33 AM
jtfrog's Avatar
jtfrog
Default 1986 cooling temp switch
I recently added a temp switch that is suppose to turn on my single cooling fan on at 200 degrees and off at 180 degrees. It is not working. according to the diagram i am suppose to connect the wire to the B terminal on my fan relay. Is there a way to make sure i am wired to the correct terminal with a volt meter. If so what seeting on the volt meeter do i use and what procces do i take to do this.
Jtfrog :cry :cry [IMG][/IMG]
