Optispark, Electrical, Fuel Pump, or Other Problem...Need Help!
I'm currently having an issue with my Corvette(1994), I'll start off with the problem. Yesterday, I was heading to lunch around 12pm and 2 miles away my car died and I had to pull over to the side of the road. Luckily, there was a tow truck driver behind me that offered to take my car back to work. When the car got back to the work parking lot it started right up, so I thought maybe everything was ok. At 3:30 I went out and started my car back up, it idled great, but died 5 minute later. I wasn't going to chance driving it anywhere so I had it towed back home. After I got off work today I started' the car up and let it idle for 30 minutes and it DIDN'T die! I don't want to drive the car anywhere until I figure out the problem because rush hour traffic is horrible and I don't want to make it worse.
I've read a lot of forums and the consensus seems to be that it's probably the optispark, but I want a second opinion. I checked the codes in the computer and it was reporting back H16 and H72. So do you guys think it's the computer, optispark, fuel pump(I can here it prime when I turn the key), or something else??? Thanks for your responses in advance!
H stands for history, as in not current.
16 is system voltage too low
72 is VSS signal circut error
My first suggestion is to check your ICM. It is located just above the coil. It is mounted to the heat sink that the coil is mounted to. It is held in place by two 7 mm bolts and is easily removed. Take it to an auto parts store and they can test it for you. If it tests bad, of course replace it. If it tests good, get some heat sink grease and apply a nice coat on the back and put it back on.
Then...using the spark tester you bought while you were at the parts store, when the car dies, check for spark from the coil.
If you have good spark, check for spark from the coil wire at the opti end.
If you have spark there, check for spark at the plugs.
I there is spark, your issue is fuel.
If there is no spark at the plugs but there is going to the opti, it's the opti.
If you have no spark from the coil, it's either the coil, the opti, or the ecm.
From there, check for voltage going to the coil.
If theres voltage, then it's the coil. If not, then check for voltage coming from the opti at the opti harness.
If there's no voltage, it's the opti, if there's voltage its the ecm.
Now, if the car just dies, as in no warning, no misfire, no otherwise bad behavior, it just quits, I'm going to bet on the icm. The heat sink wears over time, and when these overheat, they simply quit. A bad Fuel pump or regulator will act like it's out of gas and sputter then die. A bad opti could just quit, but typically will miss, backfire, then quit. But it really sounds like yours is heat related. Of course, I reserve my American Right to be wrong.
Thanks Again
Thanks Again
I also have bad news: After replacing the parts the service engine like keeps coming on and its throwing error 42. Is there something that I didn't install correctly or did I get a defective part? The car runs great now, but it's annoying that the service engine light keeps coming on.
Bad News: Took the car to work this morning and it ran fine. Went to the gym after work(Thank Goodness it's close to home) without issue. When I got into the car to go home, it was giving me problems starting, but started after the third time. It ran for 5 min, then died and I was on the side of the road. Got it started after 20 min of waiting traveled 100 yards to a shopping center where it then cut off again. Had the other two ICM's in the car just in case this happened again. Tried the other two ICM's and it still wouldn't start. Got picked up, ate dinner, came back two hours later to get the car. Car started made it the 1.5 miles to my house and it died in the front of my driveway where it sits now. Hopefully, I'll be able to get it started in an hour and put it back in the garage.
Is this starting to look like the opti-spark?
A word on advice that might save you time is to install/test the ICM first, it comes off with two bolts. Hopefully, the new ICM will fix your problem because the coil is a PITA to remove.
Keep me updated, I'll try and help if I can...Best of Luck
Junior Member
Garage is empty, add now
My Corvette Photos
I changed the ICM and it ran great for twenty minutes,then I parked it for two hours, tried to start it and wouldn't start. Put the jumper on and got only one code, H72 - gear shift selector circuit?? Anyone have any ideas??
Junior Member
My Corvette Photos
I don't have an answer for you but I would start thinking along that line of inquiry.
