Fuel injectors
Sep 14, 2013 | 11:00 AM
Fuel injectors
Did a bunch of reading today about fuel injectors. Visited FIC for additional data, but still some questions.
I have a stock 1994 6 speed.
do I replace with the 24lbs injectors.
Can you use 30 or 32, or is that a bad idea.
Do you have to go into the computer and changes some data fields with the 30/32 injectors.
Saw a wide range of prices. Based on better injectors??
24 were $389. 32 were $440. 30 were $189
Any help would be good. Also do we use LT1 edit to change the values?
Sep 14, 2013 | 11:20 AM
Quote:
Originally Posted by
rhinoevans
.....I have a stock 1994 6 speed.
do I replace with the 24lbs injectors......
Absolutely!
You will gain absolutely nothing by going to higher flow injectors.....even with a tune.
No power or drivability gains to be had at all!
If your current injectors are flowing OK, then leave them alone.
KW
Use the OEM #24 injectors.
Larger fuel injectors are for modified engines that require more fuel. Using larger injectors on a stock engine will result in, loss of performance, loss of fuel economy and poor emissions.
Sep 14, 2013 | 11:39 AM
Sep 14, 2013 | 11:44 AM
I have a set of Bosh stainless body injectors, I took out of my 90 looking for idling problems, they were just put in before I got my car.
I will sell the set for a 100 shipped.
Sep 14, 2013 | 12:33 PM
Sep 14, 2013 | 12:43 PM
bob guzzy
Which ones ?
Sep 14, 2013 | 12:44 PM
MrWillys
Seems weird that these are not listed on the LT1 page, but are in fact for LT1.
Sep 14, 2013 | 02:26 PM
Know anybody good that tunes C4's for the newer injectors through e-mail?
Sep 14, 2013 | 03:19 PM
rhinoevans
Which ones ?
Sorry for the confusion on calling them Bosh, that is what I was told they were by the previous owner, they are Delphi.
They are Delphi
http://fuelinjectorconnection.com/sh...p?productid=45
Above is from the papers I received with my car, these are what he bought, whoever installed them used the wrong donuts and they were sucking air.
You would need new donuts to install them, the rail clips are on these injectors, I installed were a different type,I didn't need the clips.
the first person in line, and it always has been here at the forum, was whomever PMed me first, and someone did.
If he drops out the next one gets them..... again I'm sorry for the confusion. B Guzz
