Air Bag deployed.....
Old Sep 15, 2013 | 01:49 AM
CorvAdel's Avatar
CorvAdel
Default Air Bag deployed.....
91 has air bag deployed.
I have done all of the tests, except one, in the FSM.
Measured resistances in both forward sensors, center arming sensor, center resistance module and they are all as per values in FSM.
I cannot find how to check coil resistance, though visually it looks ok..not burnt or seemingly damaged.
Three questions-
What caused the air bag to go off,
How do I measure the coil resistance, and
Since the resistances on the above are as needed, do I need to be replacing SIR components apart from the air bag itself?
I know the book says to replace all of the sensors, but is it necessary if values are ok?
I cannot check for codes as engine is removed atm.
TIA
