'92 vette shuts off
Old Sep 17, 2013 | 07:48 PM
Dalu's Avatar
Dalu
Default '92 vette shuts off
It started first when I tried to start eng. turned over fine but wouldn't start. Waited thirty seconds then it started. Now at times when driving down road eng shuts off, I wait a few seconds and it starts up and runs fine. Happening more frequently now. Afraid to drive it in traffic. Water pump, opti-spark, fuel pump, map sensor are newly replaced. Any ideas as to what could be the problem??
Old Sep 17, 2013 | 11:27 PM
1993C4LT1's Avatar
1993C4LT1
Since you replaced the opti and fuel pump, I'd think it's the ICM(ignition control module).
Located on the passenger side head.
Old Sep 17, 2013 | 11:50 PM
don hall's Avatar
don hall
Any codes?
Old Sep 18, 2013 | 12:24 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Possible problem in the ECM.
Old Sep 18, 2013 | 06:24 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
I would check the icm & coil.
Old Sep 18, 2013 | 10:08 PM
Dalu's Avatar
Dalu
Thanks for the idea, will replace the ICM and coil tomorrow , will post results.
Old Sep 19, 2013 | 08:53 AM
kimmer's Avatar
kimmer
I would check the icm first, typical symptoms.
Old Sep 19, 2013 | 08:58 AM
c4_4ya's Avatar
c4_4ya
Also, do a search on this forum about the ICM and heat sink- the ICM is susceptible to heat soak and there are simple fixes to help prevent this.
Old Sep 19, 2013 | 09:33 AM
Dalu's Avatar
Dalu
Will do. Thanks!
Old Sep 19, 2013 | 07:23 PM
Dalu's Avatar
Dalu
Changed the ICM and car ran perfect for twenty minutes, parked it for two hours and tried again, wouldn't start. Hooked up the jumper for code and only got one code, H72 - gear shift selector circuit?? Tried again and car started right up ran perfect. Help anyone?
Old Sep 20, 2013 | 12:46 AM
Cliff Harris's Avatar
Cliff Harris
When it won't start try wiggling the shifter. There is a switch mounted on the side of the shifter that tells the ECM if you're in Park or Neutral. It has slotted mounting holes so you can adjust it.
Old Sep 20, 2013 | 06:41 AM
Dalu's Avatar
Dalu
Thanks for your reply. How do I get to this switch? From the inside of the car or from underneath?
Old Sep 28, 2013 | 11:18 AM
Dalu's Avatar
Dalu
We'll after being convinced the problem was ignition and not knowing the history of the car so I didn't mind replacing parts. Parts replaced were ICM, ECM, fuel pump, map sensor. Previously replaced when water pump blew out was the w pump and opti. Still engine turned over but nothing. Decided to shoot starting fluid in intake and this time engine ran but like it was a diesel. Any ideas??
Old Sep 30, 2013 | 10:59 AM
nhollis's Avatar
nhollis
Cruising
My 89 shut off on me a few times and finally would not start at all. It ended up being a corroded wire connection going to the ECM somewhere around the battery. The guy I bought the car from found it and replaced the entire wire and connector. No problems with that since. Not sure if this will help, but it's worth a shot.
To '92 vette shuts off
