Intake advice for 383
Old Sep 27, 2013 | 07:23 AM
The Bus's Avatar
The Bus
Default Intake advice for 383
I just recently installed a 383 in my track car. Previously had a ZZ4 with a Super Ram which worked fine for 8 years but Super Ram was a PITA to install/remove and I wore the engine out. Before anyone says modify if for faster installation removal; I did that but it still was a PITA. The 383 was dynoed at the factory at 430 HP at the engine using a carb. I've tried getting by with a stock TPI from a 350 Corvette engine. I was hoping that it would pull to 5000 RPM but runs out of steam at around 4000 RPM. I'm using 24 lb injectors and a reprogrammed chip. I guess I'm asking what can I use if anything other than just switching to a carb?? I'm not against a carb but since I am already fuel injected I should investgate that first. I'd like to get around 390 HP at the engine. All input is wanted and appreciated.
Old Sep 27, 2013 | 07:32 AM
bjankuski's Avatar
bjankuski
Use a miniram, easy to install, and should easily hit your 390 HP goal, probably hit the 430 HP number of the carb. Other wise use a carb style intake with fuel injector bungs and an air valve.
Old Sep 27, 2013 | 08:08 AM
WW7's Avatar
WW7
Mini ram, First intake, HSR, any of these will pull past 5500 rpms ...Im running an Edelbrock intake, Accel runners, mega ported plenum all reamed out and port matched and my 383 pulled to 5000 rpms without a problem, but If I was racing my car, the Mini ram is what I would use.You lose a little torque with the Mini ram, but pick up HP.......WW
Old Sep 27, 2013 | 08:40 AM
rklessdriver's Avatar
rklessdriver
Edelbrock Victor EFI - PN 29785.
Will
Old Sep 27, 2013 | 08:43 AM
MrWillys's Avatar
MrWillys
My stock TPI runs to 5500 easily, Is your programming modified for the cam, or was the flowrate just changed? Above 5500 the intake should be changed, but stock programming is the limit below that.
Old Sep 27, 2013 | 08:48 AM
WW7's Avatar
WW7
There's a difference between spinning to 5500 rpm , and pulling to 5500 rpms...I have never heard of a stock intake setup pulling past 5000 rpms, even when heavy porting is done....And we're talking a 383 here "which demands more air" , not a 350.....WW
Old Sep 27, 2013 | 09:01 AM
MrWillys's Avatar
MrWillys
Originally Posted by WW7
There's a difference between running to 5500 rpm , and pulling to 5500 rpms...I have never heard of a stock intake setup pulling past 5000 rpms, even when heavy porting is done....And we're talking a 383 here "which demands more air" , not a 350.....WW
I think the stock intake is misunderstood is all I was pointing out. Stock programming runs out of fuel at 4400 in the power enrichment tables. Putting a Superram on a ZZ4 really does very little, except at the very top above 5000. Without knowing how the 383 is cammed, and what heads, and so on is a guess at best. 430 hp can be achieved in many different ways being long on duration with smaller heads, or short duration with more flow. If he's running a stock intake base I know it's not bigger than a 1204 Felpro, or about a 180 cc head.
Bottomline is that I was just suggesting the OP consider his programming as well.
Old Sep 27, 2013 | 09:13 AM
vetteoz's Avatar
vetteoz
Pick your poison
http://xtremecarzone.com.au/index.php?showtopic=386
Old Sep 27, 2013 | 09:38 PM
The Bus's Avatar
The Bus
Thanks C409, I'll check out that web site
Old Sep 28, 2013 | 12:11 PM
Dyno Don L.'s Avatar
Dyno Don L.
Take an Edelbrock manifold, weld up the top of each port, raise the roof 1/4" and go from 260 cfm to 300+ cfm and you will see power above 6000 rpm's.
It can still retain the tq. at low rpm's. My 350 is 400/430 @ the wheels.
400 peak @ 6000 430 tq. @ 3500.
Old Sep 29, 2013 | 08:29 AM
The Bus's Avatar
The Bus
Dyno Don. I don't completely understand what you are saying for mods. Also would a Accel SuperRam intake work??
Does anyone have a picture of a Miniram installed on a L98?? Does the fuel injection rails, intake manifold [ a Accel intake from a SuperRam setup ] already on the engine need to be replaced or just the plemium/runners.
Thanks for any additional info.
Old Sep 29, 2013 | 08:48 AM
vetteoz's Avatar
vetteoz
As per the link I posted for you above.
performance wise , the SR falls mid range between the long runner TPI style intakes and the short runner MR /SP / HSR intakes
http://forums.corvetteforum.com/1544096352-post1.html
Old Sep 29, 2013 | 08:58 AM
vetteoz's Avatar
vetteoz
The MR is a complete one piece intake that uses no factory parts and requires it's own fuel rails
See
http://www.eecis.udel.edu/~davis/z28....tpis.com.html
Old Sep 29, 2013 | 11:23 AM
The Bus's Avatar
The Bus
A big thank you guys. I'll probably buy a new unit. After fighting a Super Ram for 8 years the Mini looks like easy install.
Old Sep 29, 2013 | 11:38 AM
Aardwolf's Avatar
Aardwolf
They come up for sale used here somewhat often. I wouldn't pay full price for it new as there are other options. The MR is nice to work on! If you check my back threads I have posted pics of my combo. I switched from the SR as well. It's a good intake but I end up working on or changing my combo to much to put up with so many fasteners.
390 crank HP with a 383 seems so low but there have been a few low power combos posted lately. My 355 should be closing in on 400 wheel HP and I still don't have good heads lol
Old Sep 29, 2013 | 02:10 PM
383vett's Avatar
383vett
Earlier this year I swapped out my extrude honed SuperRam for a Miniram. I had been running the SuperRam for a good number of years. It is a great manifold that would be terrific for a street/strip car. It has great bottom/midend torque and would pull to 6500 on my 406. I was able to pull 1.40 60' times with this manifold leaving at 2000 rpm. The Miniram has required the torque converter to be loosened up and I am now leaving at 3000 rpm. 60's are the same. The car is maybe .05 seconds quicker down the quarter. So far not a big deal. I have the motor out now for it's yearend checkup and am toying with the idea of giving it more camshaft. The SuperRam does take longer to install and remove, but I did this numerous times every year and it didn't bother me. Bottom line again is if I had a car on the street, a SuperRam can't be beat. Just my observation and opinion. Willie
Old Sep 29, 2013 | 02:40 PM
The Bus's Avatar
The Bus
I run my car with NASA and SCCA. I am hoping for around 390 HP at engine or near 365 HP for rear wheels. That would be perfect for NASA ST 3. At 72 my back kills me after hours removing/installing the SR. The Miniram looks like a lot less work.
Next year could be my last year racing so I need a Miniram for installing before spring.
Again Thanks.
Old Sep 30, 2013 | 11:43 AM
Dyno Don L.
Yes, the Accel does work for that mod, in fact it is the better one to use.
I here ya on the back problem.
The only drawback to the Miniram is the rear cylinders tend to run a little richer than the front because of the low plenum.
To Intake advice for 383
