Power steering question
Old Sep 19, 2013 | 01:27 AM
vetteguy22's Avatar
vetteguy22
Default Power steering question
Hi guys,
I am running a C4 rack in my C3 project with an SRIII tube chassis. I am finishing the plumbing for the power steering but before I fill the system with fluid, I know I can adjust the pressure with shims in the early power steering pump. I am hoping someone can tell me the ideal pressure required to operate the rack properly. I don't want the steering to be to edgy. I plan on using this car on the street but also spend a fair amount of time on the road race track.
Any input would be greatly appreciated.
Thanks,
Rob
Old Sep 19, 2013 | 02:18 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Question: Since you've got a SRIII chassis, do you have a full C-4 front suspension? Putting a C-4 rack on a C-3 front suspension would be a major problem!
Old Sep 19, 2013 | 09:47 AM
vetteguy22's Avatar
vetteguy22
Yes it has a full C4 suspension with dual adjustable QA1 shocks in each corner.
Old Sep 19, 2013 | 10:44 AM
Cruizin's Avatar
Cruizin
When looking into installing a hydroboost brake unit which uses power steering pressure to operate, I was told C4 pumps operate at around 1300 to 1500lb pressure.
Not sure if that's what you're wanting to know or not?
Old Sep 19, 2013 | 02:48 PM
vetteguy22's Avatar
vetteguy22
I have a hydro boost unit installed. Am just finishing plumbing it now. Before I fill it with fluid, I thought I should make sure the power steering pump is set for the correct pressure. I believe the mustang rack is designed for around 1,000 psi. You think the C4 rack is designed for 1300 to 1500 psi? I don't want to fill the system and then have to drain it again (messy) to reset the pressure on the pump. I was also wondering if the psi was on the lower side, if it would allow more road feel instead of being to light feeling, if that makes any sense.
Rob
Old Sep 20, 2013 | 12:05 AM
Cruizin's Avatar
Cruizin
Tracked an 86 C4 pump pressure down to 1200 -1300psi. (My initial pressure posted above came from various unsubstantiated forum posts).
I'd imagine most C4 pumps will be about the same but you can post your questions here for reliable advice:
http://www.turnone-steering.com/tech...p/post/1972028
http://www.turnone-steering.com/technical-help/
To Power steering question
