No spark
Old Sep 19, 2013 | 10:48 PM
bassackwards's Avatar
bassackwards
Default No spark
I apologize up front for being lazy and not searching but I'm whipped.
I spent 14 hrs today retrieving 2 LT1 vettes today and the 1993 that was supposed to run would not start when I got there. No spark when cranking the engine. I tried sticking a different plug into the wire and nothing at all.
Thankfully I invested in a giant winch for my trailer so I didn't have to use Armstrong to get it loaded.
Where should I start troubleshooting?
Old Sep 20, 2013 | 07:41 AM
eatmydst1234's Avatar
eatmydst1234
Check for spark out of coil.
Old Sep 20, 2013 | 08:53 AM
Jmhornz71's Avatar
Jmhornz71
I had the same problem twice,, engine would turn over but not fire. First time it was the PCM and optispark, second time about a month or so later it was the coil and ignition control module same thing engine would turn over but not fire
Old Sep 20, 2013 | 11:50 AM
bassackwards
no spark at coil and no injector clicking. SES light appears disabled. I am going to check for codes through the speedo but the battery has been out.
Old Sep 20, 2013 | 12:59 PM
bassackwards
I got an H16 and an H42 when checking the codes.
I plugged another opti in and spun it with a drill and got injector clicking
Old Sep 20, 2013 | 01:11 PM
leesvet's Avatar
leesvet
Buy a FSM for any LT and that will give you the diagnostics for any of those cars. Without it, you're looking at guessing with some expensive parts.
Old Sep 20, 2013 | 03:32 PM
eatmydst1234
H16 points to opti low res pulse
Old Sep 20, 2013 | 04:16 PM
bassackwards
OK I erased all the codes and started fresh. I kept getting H42
I swapped out the icm and the coil since I had one of the parts car and she started!
Now I'm getting an H14 so I'm trying to find that plug now to see if it is even connected.
Old Sep 20, 2013 | 06:30 PM
bassackwards
H14 was caused by skinned wires going to the water pump sensor. Fixed!
To No spark
