throttle body question
Old Sep 26, 2013 | 08:48 AM
Ranman#1's Avatar
Ranman#1
Default throttle body question
Does anyone know if an OEM 1996 throttle body will fit onto a 1985? Are any modifications required? Is there anything I should think about? I also have an Upgrade to the 1996 OEM as well. I think it is 450 cfm. would either bolt right on? what benefit would this give me?
I am not very mechanically inclined as you can tell.
Old Sep 26, 2013 | 01:37 PM
WW7's Avatar
WW7
It should bolt up, but the 85 and 96 linkage are different..I don't see any benefit, just a lot of work changing the linkage...Im still using the stock throttle body with close to 400 hp in my 89 , so I can't see it doing anything to add power to a stock motor.... ..WW
Old Sep 26, 2013 | 01:52 PM
John A. Marker's Avatar
John A. Marker
Stock 48mm TB on the 85 will support up to about 400 HP. No benefit to making the change.
To throttle body question
