information console and code pulling woes
Old Sep 30, 2013 | 01:12 PM
85corvettec4's Avatar
85corvettec4
Default information console and code pulling woes
when i bought the car the only lights that would illuminate on the info console were the hatch ajar and brake lights. then after awhile it stopped coming on. so is this lights or would i need a new panel? and when i had hooked up a obd1 scanner to the car it had no codes even though the car was carbed at the time and should have been throwing them left and right.
Old Sep 30, 2013 | 02:27 PM
c4cruiser's Avatar
c4cruiser
It could be that a prior owner had removed some lights from the DIC when the carb conversion was done. There is a block behind the DIC screen that contains a number of lights (168 or 194 bulbs). The only bulbs in place should be those that were actually needed based on the options in the car.
It may also be that a custom chip was put into the ECM that would ignore any input from sensors. It may also be that some sensors were removed. Then the OBD1 reader would not see any stored codes.
Old Sep 30, 2013 | 03:17 PM
85corvettec4
i have all the sensors in, and once i get the car to start i should then be able to pull codes if any exist? any way to tell for sure if the ecm had been tinkered with?
would the whole panel die in itself or is it more likely power got cut somewhere?
Old Sep 30, 2013 | 04:51 PM
c4cruiser's Avatar
c4cruiser
The DIC is nothing more than a number of light bulbs in a divided box with a lens cover containing lettering for specific warnings. There are a maximum of 12 lights although I think that for the '85, a few positions aren't used.
The ECM doesn't control all of the warning bulbs. Bulbs for things like door ajar, Security, hatch open, seat belts, and the brake light are controlled by those circuits. If those don't light up at some point, it's likely that the bulbs are burned out or something in that circuit is disconnected (bad connector, bad relay, broken wire, bad sensor, etc.)
When you turn on the ignition switch but don't start the engine, what lights up on the DIC?
Old Sep 30, 2013 | 06:15 PM
85corvettec4
nothing lights up except my cluster
Old Sep 30, 2013 | 08:03 PM
vetteoz's Avatar
vetteoz
Old Sep 30, 2013 | 08:39 PM
vetteoz's Avatar
vetteoz
The only thing they have in common is they have the same 12V power supply through the same fuse
To information console and code pulling woes
