looking to change the covers on my 85....been checking around..ecklers has chevy "350" chrome at 40 bucks a pair but the polished aluminum with the c4 logo are 240-300 a pr depending where you look...am I missing something? whouldn't chrome look better.???...I am chroming the manifold/runners/ etc anyway....are there better ones out there?...figured you guys would know...and as a side note....I did call arp to order the bolt kit....neal nice..but he told me to call summit...they'd be cheaper...i did...they were....a lot...thanks guys....
Those chrome ones are just stamped steel with chrome plating. The Aluminum ones are probably machined and then polished. A lot more cost to produce. Aluminum dissipates heat faster. But I see your point. Its hard to justify 3 bills for valve covers.
Fleabay?? Lookit the pic of my '85 L98 left. I got those for $80 new. Make sure what you buy has the proper holes for your app. I used an old school ported oil breather/cap for the right side. Port is for the CCV and goes to the TB. I pop it out to use for the oil fill. Left side is for the PCV.
be aware that any covers taller than stock will hit the windscreen wiper motor on the left hand side, before you buy any measure yours and how much clearance you have and check exactly how tall the ones you're buying are,
in the photo below you can see where mine had to be cut and welded to clear the wiper motor,
thanks...nice pic.....hope I can get mine to look similar...i'll make sure they're stock...no need for anything else... wanted that corvette logo on them....looks like summit proforms will do....
I dont know about your '85 but my stock covers leaked like crazy, the aftermarket alloy ones are dead straight and dont leak,
I also used a thin flat rubber gasket on the left, it gives more clearance from the wiper motor
I cant find Chrome or polished valve covers in the centerbolt pattern for my 86L.
Getting really frustrated and sorry I started.
How many do you need ? First page on ebay.
http://www.ebay.com/itm/SBC-Small-Block-Aluminum-Short-Finned-Chevy-Center-Bolt-Valve-Covers-305-350-/111529874556?pt=Motors_Car_Truck_Parts_Accessories&hash=item19f7b2d47c&vxp=mtr
The third hole is just the oil filler. You can pull out the PCV hose to add oil. My 87 is the same as your 86L. I used to have one of those too. For a while I was using the billett ones, but they did have an oil filler hole. If you get something like that, get chrome. The non plated ones are hard to keep polished. Mine were like this.
Now those look good! So your saying the chrome stays better then the polished aluminum? I know the Aluminum dissipates heat better but I wonder if that makes such a big deal on valve covers?
$49 and I can get C4 emblems for it...... Thanks bro. I just might use these. they look great. But this is what kills me........the charts say 88 and up. will those fit my 86L? thanks man.....
The late 86 is pretty much the same as the 88. They will work. The plain aluminum looks great but I had to work a bit to keep them looking that way. I drive mine every day. If you drive less, maintenance will be less.
