I failed emissions yesterday and am looking for suggestions.
I got a Code 44 left bank lean while idling in the line for an hr. I shut the car off when I got in and restarted it. The light stayed off but came back on when she had the sniffer stuck up my rear.
I got high HC and high CO.
Yesterday afternoon I changed the air filter and added a bottle of Chemtool to the tank. Today the darn light came on again. I just checked for vacuum leaks and cleaned the IAC and butterflies and let it idle for a while and no light.
With all the idling in your description, it could be O2 sensors or catalytic converters. The cats have to be hot to work properly. The O2 sensors have to be clean. Not sure about chemtool product but some additives aren't friendly to emission readings.
I failed emissions this spring. My emissions were 10 times higher than the limit (tail pipe sniffer test).
Here's what i did. I changed from premium to regular grade for a week or so. then I let the gas get down to about a quarter tank, and bought a gallon of denatured alcohol from Lowes, put it in the tank and went back to take a re-test. Passed! Not by much, but it passed! Treated the Corvette to a tankful of high test and haven't had any problems since.
It may not work for you, but for a $14 investment (gallon of alcohol), it can't hurt.
It smells rich though.
Hi CO is rich, makes sense it smells rich.
However showing lean left bank.....You have an exhaust leak- extra air gets pulled in and gives a false lean to the O2 sensor-computer adds and adds fuel trying to make up for it.
Better be careful with the denatured alcohol. It'll eat up the rubber bladder in your fuel cell and every rubber line between the tank and motor.
I pulled a plug on the left side and it was pretty black, not what I expected. I pulled the O2 sensor which came right out and it too was black.. I cleaned it up and put it back and got the same 44 code.
I had a similar code. Bad O2 sensor was the culprit.
It had the ECM correcting what was sensed as a lean condition and it was dumping fuel in to compensate. I had the fuel smell, too, like it was running very rich.
A new O2 sensor, not simply a cleaned one, and I was on my way. These cause so many issues when they fail and running rich is a typical symptom.
Just a suggestion and it isn't too expensive.
This is what I figure. I will order it tonight. Should I just replace both? They are probably original 21 yr old parts.
I actually had this happen twice. A '91 350 TBI pickup that I had for years also threw a lean code, and again it was the sensor.
On the '92 LT1, I replaced both sensors since I was already working on the car.
They screw in to the sensor bung sort of like a spark plug. Unfortunately, they have a wire coming out of them, so a standard socket won't go over them.
On the truck I was able to use an open end wrench and on the Vette I used a crows foot socket. Both times I sprayed some PB Blaster penetrating oil on it to get it loose. I cleaned that up real well before I put in a new one. I would think it's not good for the sensor.
Open end wrench, crows foot socket or one of the actual sensor sockets should work if you have the room to work on it.
10-4- I had heard that alcohol in high concentrations was bad for the systems.
I made sure to go and fill the tank right away with real gas! Alcohol isnt quite like acid- it takes a while of using it to do damage. The crazy thing is that i had passed emissions with no trouble two years earlier, and hadn't done anything to change the 'tune' on the engine.
In any case, pretty soon the alcohol was very diluted and passed through the engine. I didn't want to take any chances on damaging my fuel system.
