chatter in reverse
Old Oct 2, 2013 | 12:16 AM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default chatter in reverse
My 700r4 chatters when I put it in reverse. Almost like when your about to stall out on a regular stick car. The Tranny has about 5 thousand miles on it. It worked fine before I did a lot of work on the engine. I changed out the TV cable and put in a new filter and tranny fluid. I checked the fluid while the car was hot and the level looks good. Im thinking I adjusted the tv cable correctly. I called a tranny shop to get instructions. Anything I can check before I drag it to the tranny shop for a repair I cant afford.
1986 chevy corvette
automatic rebuilt about 8 years ago. Cars been sitting months at a time.
fluid looks good
