Vapor Lock on C4
Old Jul 3, 2002 | 06:30 PM
dlsmith's Avatar
dlsmith
8th Gear
Default Vapor Lock on C4
I have an 85 C4. In hot weather, after driving it and getting it hot and then parking for 30 - 45 minutes, it is hard to start. It will start and then die. If you give it a little gas, it sounds like it is dieseling and then die again. So far I have been able to finally get it to start and stay running.
Could this be a timing issue? Suggestions?
Thanks!!
:confused:
Old Jul 3, 2002 | 06:35 PM
scorp508's Avatar
scorp508
You most likely have leaky fuel injectors. I would look into getting a new set or having yours serviced.
Old Jul 3, 2002 | 06:36 PM
lowflyer's Avatar
lowflyer
Cruise-In I Veteran
Default Re: Vapor Lock on C4 (dlsmith)
I agree. With 30-40psi of fuel pressure, its pretty unlikely that you are getting a vapor lock problem. Put a fuel pressure guage on the rail and see what your pressure is after shutdown. Good luck.
MagRed_04's Avatar
MagRed_04
Mine did a similar thing... It turned out that when it was hot, the fuel injectors were leaking gas into the cylinders creating a "flooded" condition.
You might want to have your injectors checked. Are they original? My '85 injectors were shot at only 50,000 miles.
:cheers:
Old Jul 3, 2002 | 06:38 PM
KYVette90's Avatar
KYVette90
Default Re: (scorp508)
Mines doing the same thing. It's the injectors. I'm sending mine off pretty soon to be redone. :cheers:
Old Jul 3, 2002 | 06:59 PM
Rynda's Avatar
Rynda
Mine is doing the same thing. I replaced all of my injectors with a new set of Accel injectors (24lb) from Summit a few months ago. I hope that it is not the injectors. After heat soaking for ~ 20 minutes, the vette starts right up and then dies after a few seconds (enough to get into traffic :eek: ). It does not pull that trick every time, but often enough. After cranking on it for a few seconds it will fire up and continue on as if nothing went wrong. I'm puzzled.
Old Jul 3, 2002 | 07:50 PM
jfb's Avatar
jfb
Put a fuel pressure gauge on the shraeder valve on the fuel rail and turn on the ignition sw for more than 2 seconds. The fuel pump runs for 2 seconds and shuts off which will build fuel pressure. GM says that you shouldn't lose more than 1 psi in 30 minutes or the injectors are considered leaky. This test will prove it.
Old Jul 4, 2002 | 11:30 AM
merrick's Avatar
merrick
Electronic fuel injection does not vapor lock!
To Vapor Lock on C4
