QUICK!!! gas gage problem
Old Jul 3, 2002 | 07:23 PM
mn_vette's Avatar
mn_vette
Default QUICK!!! gas gage problem
I'm sure you've noticed that with the electronic gages the gas gage acts funny it takes a long time to get through the first bar and a little shorter time to get through the second bar and so on and so on until a quarter of a tank only last a very short while before it's out.
I've got my sending unit out of the car right now changing a fuel pump, is there anything I can do while I've got it apart to fix this?
Old Jul 3, 2002 | 07:46 PM
nobodyunknown's Avatar
nobodyunknown
Default Re: QUICK!!! gas gage problem (mn_vette)
Its probably the dash not the sender.
The sender is only a reastat,which means you can put other senders on there.
You should see it go from 10 to 90 on a ohms meter when you check across the terminals & move the float.
P.S. its spelled gauge.
:chevy
Old Jul 3, 2002 | 07:54 PM
mn_vette's Avatar
mn_vette
Default Re: QUICK!!! gas gage problem (nobodyunknown)
thanks for the english lesson :sad: That's why I'm an engineer :D I'll do the math all day long, but don't ask me to do anything even remotely close to gramar
To QUICK!!! gas gage problem
