loose brake caliper
Old Oct 5, 2013 | 11:38 AM
octaneforce's Avatar
octaneforce
Default loose brake caliper
my front passenger side brake caliper keeps coming apart. the pin comes out and it seperates from the bracket and rubs on the inside of the wheel. i keep buying the caliper hardware kit and putting it back together but the same thing always happens. i dont know whats wrong. it looks identical to the drivers side which has never come apart.
heres the hardware kit minus one pin, washer, and c clip. i dont know what the black things are
Uploaded with ImageShack.com
heres a shot of the caliper assembled
heres a video of whats happening. its much worse when the wheel is on.
http://s153.photobucket.com/user/isl..._2610.mp4.html
Old Oct 5, 2013 | 11:39 AM
octaneforce
1989 6 spd base
Old Oct 5, 2013 | 11:48 AM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
It looks like the groove in either (or both) the abutment bracket and caliper is worn. I'd check those out vs. the other side if you can.
Old Oct 5, 2013 | 11:56 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Had the same thing happen to me when autoxing. I put on heavy duty clips and also built up the caliper bracket pin area to raise the pin just a hair and have had no more problems.
Old Oct 5, 2013 | 12:02 PM
octaneforce
I was thinking of that. They do look a tiny bit rounded out. Im surprised the tolerances are that close
Old Oct 5, 2013 | 12:03 PM
octaneforce
I have to bring spare pins with me to autox. What did you use to build up the pin area?
Old Oct 5, 2013 | 12:32 PM
octaneforce
What if i replaced the pin with a bolt
Old Oct 5, 2013 | 02:16 PM
kimmer's Avatar
kimmer
I think I used the long end of a pop rivet so it would be soft enough to form itself into the groove.
Old Oct 5, 2013 | 10:02 PM
octaneforce
You just shoved it under the pin?
To loose brake caliper
