anybody using vemaster?
Old Oct 6, 2013 | 05:05 PM
93 ragtop's Avatar
93 ragtop
Default anybody using vemaster?
Just wondering if you like it and if it helped?
Old Oct 8, 2013 | 11:30 AM
drive it's Avatar
drive it
Yup, I've used it quite a bit-works great! There's also a vemaster-ee for later year bins.
Old Oct 8, 2013 | 11:53 AM
93 ragtop's Avatar
93 ragtop
Thanks for your reply!! Do you know if it can cause any problems to run it several times?
Old Oct 8, 2013 | 04:41 PM
STL94LT1's Avatar
STL94LT1
You will need to run it several times to get your tune dialed-in.
Old Oct 9, 2013 | 08:35 AM
93 ragtop's Avatar
93 ragtop
Thanks for your reply. One other question, I had read where it is best to leave the blm default set at 124. Is this true?
Old Oct 9, 2013 | 05:01 PM
STL94LT1's Avatar
STL94LT1
The thought behind tuning to 124 blm at cruise is that some pcms will not lock in to 128 blms if you are above 128 at the time you go into power enrichment (PE) mode. My 94 isn't one of these it will lock in at 128 even if I am above at the time PE mode is reached. I tune as close to 128 blms as possible.
Old Oct 10, 2013 | 07:30 AM
93 ragtop's Avatar
93 ragtop
mine being a 93, not sure which way it would go. But at any rate, I kinda have a setback. The throttle body cable broke and I am in the process of trying to make one. If not, I will have to try and find a used one. They are discontinued item.
To anybody using vemaster?
