AC/Heater Control
Old Oct 9, 2013 | 02:19 PM
dustyjoe57's Avatar
dustyjoe57
Default AC/Heater Control
My 89 C4 base Coupe's AC/Heater panel display will not light up when lights are on... Is replacing panel only option?
Joe S.
Old Oct 9, 2013 | 03:56 PM
Red86Z51's Avatar
Red86Z51
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
No, you can replace the lamps. I replaced mine in my '87 (C68) with JKL 37 bulbs which are T1.75 14V .09A sub mini wedge bulbs, which required removal of the control head from the car, then removal of the faceplate from the housing. All of those parts are easy to disassemble. The bulbs are in small "twist-in" sockets on the back of the board.
Old Oct 9, 2013 | 10:07 PM
dustyjoe57's Avatar
dustyjoe57
thank for the quick reply!!! will check it out this weekend.
Old Oct 9, 2013 | 10:20 PM
Phosgene's Avatar
Phosgene
i have an 87 Z52 with the manual heat/ac controls
when i turn the fan setting to maximum it turns the heat/ac off
what is the cause of this
To AC/Heater Control
