coil springs
Old Oct 10, 2013 | 03:54 PM
jseremba's Avatar
jseremba
Default coil springs
has anyone installed coil springs on there Corvette? I own a 1984 with a 4 plus three. I just wondered if anyone has done a coil spring swap and where thet satisfied with the result.
Old Oct 10, 2013 | 04:19 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Quite a few here have done this swap (I have not).
I have never seen a bad review of the swap (other than difficulty with fitment), but it should be noted, that the primary advantage people see with the swap is swapping from old/worn shocks, to new, high quality adjustable shocks as part of the swap; IOW, the would have seen about the same improvement by simply swapping the shocks.
The advantage that coil springs provides is adjustability (generally) for tracking/road racing a car. Nobody changes their corner weights on a street driven car.
Old Oct 10, 2013 | 04:49 PM
jseremba's Avatar
jseremba
I was just wondering about the swap. It just seems like the leaf spring ties the car together in away that the right hand side affects the left. Where a coil spring suspension would be more independent.
Old Oct 10, 2013 | 05:42 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
And "more independent" would be better?
You're thinking is correct...in the front only. Rear, the way that the leaf spring is mounted, it's effectively totally independent. Of course, both front and rear of the car have a sway bar that ties both sides of the suspension together anyway, to achieve "flat cornering" (less body lean).
By going to coils in the front, you eliminate that "linkage" between sides, and therefore, you need to add a larger front sway bar to create the same effect that you have now, with regard to flat cornering.
Old Oct 10, 2013 | 10:10 PM
jseremba's Avatar
jseremba
Thank you for the great explain.
Old Oct 10, 2013 | 11:23 PM
vetteoz's Avatar
vetteoz
I just wondered if anyone has done a coil spring swap .
Some mods required on early cars
http://forums.corvetteforum.com/c4-t...ck-towers.html
http://forums.corvetteforum.com/c4-t...lover-mod.html
Old Oct 11, 2013 | 03:55 AM
jseremba's Avatar
jseremba
Thank you
Old Oct 11, 2013 | 10:41 AM
jseremba's Avatar
jseremba
A couple of things.
1) I searched c4 tech and performance for coil springs.
nothing even vaguely related to coil springs came up.
2) the article does not say it but I am assuming that the leaf spring is still in the car and the coils are supplemental.
Old Oct 11, 2013 | 01:47 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
1. Everyone on here calls them "Coilovers" or "Coil overs". Try try searching for that.
2. Not typically. Typically, the coil springs replace the monoleaf.
Old Oct 11, 2013 | 03:44 PM
jseremba's Avatar
jseremba
Just trying to learn how to use the site thank you
Old Oct 11, 2013 | 06:03 PM
qws's Avatar
qws
yep, did my 84
http://forums.corvetteforum.com/c4-t...-lowering.html
To coil springs
