Knock sensor
Old Oct 11, 2013 | 01:19 AM
adtbrown's Avatar
adtbrown
Default Knock sensor
I've been chasing an overheating problem in my 93 6 speed coupe for quite some time. I've been through 3 thermostats, 2 radiators, a water pump and hoses trying to make it run as cool at 1200 rpm as it does at 3000. In another thread, another member suggested that perhaps I've got a bad knock sensor making it run too lean and perhaps not backing the timing off enough. I've got single chamber Flomasters on it, so I'm guessing if it was pinging, I would not hear it. Thoughts?
Not that it should affect engine temp, but I also installed a new Opti Spark while the water pump was off.
Old Oct 11, 2013 | 02:03 AM
adtbrown's Avatar
adtbrown
Also, I have no "Check engine" light or stored / current codes.
Old Oct 11, 2013 | 04:08 AM
vetteoz's Avatar
vetteoz
A knock sensor only records knock so the ECM can retard the spark timing
; it has no direct affect on the amount of fuel supplied
Old Oct 12, 2013 | 01:37 AM
Cliff Harris's Avatar
Cliff Harris
If you think the knock sensor is causing a problem then you can unplug it.
To find out what is really happening you need to use a scanner or (preferably) scanning software.
Old Oct 12, 2013 | 09:02 AM
WW7's Avatar
WW7
with Cliff, most times a scanner will show you what on your motor is working right and what's not...A motor running lean can cause higher temps and a scanner would show that.. It also shows what all the sensors in the motor are doing... It's hard to diagnose these cars without a scanner....WW
Old Oct 12, 2013 | 09:50 AM
MrWillys's Avatar
MrWillys
If the knock sensor was retarding timing too much it could cause a hotter running engine. A diagnostic tool as has been suggested is the best way to observe knock sensor operation. Early LT1's were prone with knock sensor issue's. However, usually it sets a code?
To Knock sensor
