Aqua,
They don't do anything for the SFI Vettes (94-96). The PCM will tune out any advantage within a few miles of part throttle driving. If your stock FPR is working fine, don't bother.
Re: Adjustable fuel pressure regulator? (silver & red CE)
I did not know this.
Aqua,
Dyno graph and discussion of this mod. The computer compensates for the lower pressure by extending injector pulsewidth.
Any way around this? Looks like leaning the mixture provides for some nice numbers!
I think you can mitigate this by disconnecting the o2 sensor at the track.
If you disconnet your sensors, the PCM will run the A/F very rich to be sure not to lean out. The performance of your motor will be degraded by the PCM to protect the motor. In other word, don't do this if you want to go fast.
I've seen posts on the f-body and Impala forum/digests discussing a circuit that goes between the MAF connector and the PCM. It lowers the apparent air reading into the PCM so the mixture is leaned out. You just use it at the track, during WOT only, otherwise the PCM will compensate the adjustment out. The best way to fix this problem is to have your car dyno tuned and have the WOT part of the program adjusted.
Another thing to consider. The instructions I got with the TPIS regulator also suggest turning the pressure DOWN but I suspect this is for best performance at the strip (i.e., WOT condition). My car is just a daily drive and has never seen the strip but I, mistakenly, tried running at a lower-than-stock pressure (39 psi as recommended by TPIS). The car ran poorly on the street, however I guess WOT performance would have been better.
So if the car is just used on the street, it might actually make more sense to kick the pressure slightly above stock. It is true that the computer will compensate for any non-WOT settings by increasing or decreasing the injector pulse. However, it seems to make sense to have a higher pressure/shorter pulse combination versus lower pressure/longer pulse since with the higher pressure, I have heard it argued that the fuel is atomized better. Of course I may be wrong.
65Z01,
Have a look at the entire thread. It doesn't do squat on the 94-96 LT1/4. The PCM will adjust out any gains within a few miles of part throttle driving. Not L98s, but 94-96 LT1/4.
