85 manual door locks
Old Oct 14, 2013 | 07:45 PM
sturmmorser2000's Avatar
sturmmorser2000
Default 85 manual door locks
Is it possible to have only manual door locks and not use the power door locks?Will the key unlock it if the their is no power to the power door locks?
Old Oct 14, 2013 | 08:34 PM
sturmmorser2000
With the key in the lock and the door locked do you turn the key to the right or the left to unlock?My lock is stuck
Old Oct 14, 2013 | 09:54 PM
sturmmorser2000
Is it possible to unlock the doors without the actuator being connected?
Old Oct 15, 2013 | 12:04 AM
xrav22's Avatar
xrav22
Squirt motocycle chain lube in there with the straw they will work like new again if you are lucky mine did.
Old Oct 15, 2013 | 04:01 AM
Cliff Harris's Avatar
Cliff Harris
Yes.
Turn the key clockwise to unlock.
Yes.
Old Oct 15, 2013 | 07:08 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
In where?
Not the lock I hope you don't mean
Old Oct 15, 2013 | 11:30 AM
xrav22's Avatar
xrav22
Yes in the locks, it is a light oil that is sticky and will last a long time(not like wd40)
It coats the rollers nicely. It won't hurt the alarm since that trigger is not inside the lock.
Just a squirt, if your locks are stuck and not broken it should work loose by going back and forth. I have doen this for 20 yrs on all lock.
Old Oct 16, 2013 | 01:56 AM
Cliff Harris
Motorcycle chain lube is grease that is diluted by alcohol. The alcohol evaporates and leaves the grease behind. I wouldn't put that stuff in my locks.
The recommended lubricant for locks is graphite. It's dry and won't leave a greasy residue on the key. Molybdenum disulphide powder also works well. This is the right stuff:
http://www.thepaintstore.com/AGS_3_4...m?1=1&CartID=0
Old Oct 16, 2013 | 02:58 PM
sturmmorser2000
I sprayed some wd40 that says on the can its safe for locks into the keyhole.Still no dice.I may have to take off the door panel and spray some on the other side of the lock where it moves the mechanism.
Old Oct 26, 2013 | 06:57 PM
Cruisinfanatic
Bad idea. Chain lube is GREASE!
Old Oct 27, 2013 | 09:20 AM
HlhnEast's Avatar
HlhnEast
Check the rods that actuate the actual locking button on the inside of the door and the one that runs thru the nylon guide in the aluminum sub panel. They may be bent or otherwise hanging up.
Old Oct 27, 2013 | 01:52 PM
xrav22's Avatar
xrav22
Chain lube is a light bubbly grease, how can that be bad for rollers in a lock.
It does not freeze up a lock even in cold weather. Please explain.
http://www.2wheelpros.com/pj1-chain-...FUfZQgodSjAAcA
To 85 manual door locks
