Still overheating
Sitting at a stop light or in heavy traffic, running in the 220 - 235 range is normal.
But at speed, it should run very close to the thermostat setting (190 - 195 range).
My '96 will stay at 190 - 195 all day long on any road and any gear, as long as it's moving above 35 mph.
So one has to "Question" his instrumentation at some point in time.
Here's an article I wrote a few months back about cooling systems.
Richard Newton
1. Are you using LT1-4 t-stats, they are different then std. SBC t-stats.
It's holding, mostly around *205, but will creep up to 212 at lower RPM, but I can cool it off by dropping to a lower gear and holding it above 3000 rpm, which will drop it to 195.
2. Is the T-stat a 180 or 160. 180 is factory oem. and because the water runs through the heads first, and then to the block, it will read at least 195 at the sensor. This is the reason the factory LT1 tstat is a 180 yet it will run as hot or hotter then a std sbc with a 195.
I thought I'd post this before I pull the heads and see if anyone has any thoughts. Like I said, it's mostly stock, with the exception of true duals, Flowmaster mufflers and throttle body coolant delete.[/QUOTE]
3. Have you reprogrammed the computer to bring the fans on earlier and again is it the 180 t stat.
I don't believe you will ever get below 195-205 with factory programming and factory t-stat.
How do you figure that? My experience has has always been I make more power the cooler I can get the car before staging. Every tuner I have spoke to recommend using a 160 t-stat to make more power. Go over to the drag racing section and see what everyone uses. If that is not enough, here is a carcraft article saying the same. http://www.carcraft.com/techarticles...t/viewall.html
Again, could you explain how its best to be at 220-240 for most power?
Those are good numbers..better than most.
You have to learn to STOP thinking 'old school' when cars ran at 180.; C4's DO NOT and it is NOT good to try to make them run that cold...
There are a doz great reasons why it should run at 200 to 225 in ambient temps of 90* with the a/c on.
You have nothing to worry about. I would be far more concerned if mine tried to stay under 200 on an avg day.
There is no coolant loss?
Are you certain about VAC leaks?
even with the variations you describe, there is still not any extreme temps. Head gaskets will send the temps thru the roof if its eating the water or it will pressurized the system and force all the water out the overflow tank. The temps come from the loss of coolant. If there is water getting in a cyl there will be a spark plug that looks steak cleaned....very different from the rest.. That is, IF you have coolant loss.
2 things have to happen. Water HAS to circulate freely. Air has to pass over the condenser to remove heat from the water.
That's it.
You MAY have to do some trial & error research. I would remove the T-stat and drive it like that for a few days and see how it behaves. Look in the filler and watch the water FLOWING thru the core. Look for bubbles, surges, note the water level as the engine revs and decelerates.
You may be seeing temps go up from the engine lugging slightly. The more it struggles the hotter it will get. Dropping down a gear puts it in a better power range....again, more rpm generates more heat and with a bad gasket, a worsening of the symptoms, not an improvement.
You have checked the gauge for accuracy? infra-red sensor to confirm? any other significant SES codes?
I had a similar cooling issue a few months ago that was causing all kinds of bizarre symptoms, AND coolant loss. Nothing seemed to be wrong. I took **** apart, put it together again. I started to conjure up the dumbest theories you can imagine to "make" a problem that I could comprehend...I had half these guys thinking about it as well.
Turned out to be a PIN HOLE in a very short heater hose under the a/c compressor. It never leaked a drop....too small. But it did spray a very fine mist toward the #2 exhaust where I can assume it was instantly vaporized without leaving ANY trace of coolant. I was getting NO circulation from the pump at times....this was explained later. As the mist voided the cooling system when it was shut down, the pump cavity was emptied and the surrounding hoses as well. Next start up the pump would be turning dry...no coolant anywhere close. With a closed T-stat the water could not self-level as you think it would.
Simple problem. Even easier solution. Damn difficult to diagnose mostly because I was OVER-THINKING the whole issue...
A pin hole in a hose....I was shopping for short blocks and rebuild kits because I was SURE it was a head gasket and/or some seriously damaged hard parts.
"......Most of us worry too much about our temperatures. In discussions with several engine builders and radiator manufactures there was agreement that it’s best to run in the 210 to 220 range. Even 240 is not a problem under the right conditions."
"At the end of the day it seems that people worry entirely too much about coolant temperature. Running a racecar with a 160 degree coolant temperature probably won’t happen. Even if it happens it’s not a good idea. Cooler is not necessarily better. You need to be in the 210 degree range."
".....Heat is a good thing. Especially when you’re dispersing all of that thermal energy back into the atmosphere."
Yeah.....I agree that heat is a good thing. If your goal is to go around, warping heads.....
KW
The radiator people I spoke with are DeWitt and C and R Racing. C and R has shop in small town in North Carolina. It's called Mooresville. There are a few race shops in that little town.
Seriously though the world has changed. I went back and checked my data sheets. I normally run about 210 water and 250 oil temps at both Sebring and Homestead. Both will get a little higher if I'm at the limit for a few laps. No big deal though.
The short track guys are the ones that run 240 degrees. As I said that's pushing the envelope.
Richard Newton
Richard Newton
Your 'flush post' didn't include removal of the two knock sensors. The knock sensors are located in the bottom of the block. Heavy contaminants will settle at the bottom of the block, which acts much like a sump, eventually building up, and restricting coolant flow. Flushing will remove contaminated coolant, but not the sediment in the 'sump'. Only by removing the knock sensors can you clean out the 'sump'.
Cleaning out the sump requires more than just removing the knock sensors and draining the the coolant. Water sprayed into the knock sensor holes is required (may take several application for a thorough job.
If the knock sensors have been replaced, and the sediment removed...... I'm not much help.
With the lack of cooling flow idea. As you rev the engine up you increase the water pump speed which will increase the speed that the water flows through the engine. Depending on where the temperature readout is located this could cause a decrease in the gauge reading since the water in the engine is moving faster it may not have as much time to pick-up heat which may show a reduction in temperature on the gauge. (I am not saying that the actual temperature of the engine is any different what I am saying is the gauge may be located in a spot that is effected by flow. The actual heat rejection of the engine to the air may still be the same)
..WW
