Question about shorty headers
As you can tell I'm in the dark about most info on headers. But with long tubes, you pretty much have to replace the entire exhaust plumbing from header-back with after market, right? I was looking for a way to open up the exhaust flow over and above stock manifolds without having to completely scrap the stock exhaust system.
I was thinking about doing shorties and trying to keep the rest of the stock exhaust system except replace the mufflers with Magnaflow mufflers & LT1 tips. Would I see any better mid and high range power out of this kind of setup (without losing any low end grunt off the line)?
I hope I haven't sounded to moronic... :D
[Modified by Lone Ranger, 9:52 PM 7/4/2002]
I think i would stick with the stockers and just change the catback, but i'm no expert on LT's either.
I'm still bolting my exhaust in. Once done, I'll try to re-dyno and see what kind of increase I got.
If cats are not required, all you need to do is have an exhaust shop cut the passenger side pipe a little and put a collector fitting on it. On the driver's side you MIGHT have to extend it a little and put a collector fitting on it. Nothing that any competent shop couldn't do for like $50. I paid $100 for mine and they fabricated an X-pipe to replace the resonator at the same time.
If cats are required it gets more complicated, but still nothing a good exhaust shop couldn't do cheap, you'd just have to buy some bullit cats, that would be the costly part.
As for HP gains I had the hot cam already installed, I picked up 23 hp and 32 pounds of torque with the headers. This also kicked my 1/4 mile trap speeds up from 109 to 112 consistently. My times didn't really improve because I still have a lot of learning to do as far as racing at the track. I can tell you this, the headers were just as much of a kick in the pants as the cam was.
As for shorties, the vette shorties are simple, there might be some gain there and it will certainly make the engine look cleaner. The F-body shorties are a terrible design and don't help one little bit.
I'm afraid I don't have any pictures of my catless cat back, but I do have some engine compartment pics of the long tubes installed. Check out my web page http://www.wku.edu/~nathan.plemons
[Modified by Bluewasp, 9:09 AM 7/5/2002]
