abs help
Old Oct 16, 2013 | 10:52 AM
bvectra's Avatar
bvectra
Default abs help
I've been autocrossing a 92 lt1 and don't feel the pulsing of the abs unit. If I slam on my brakes then the abs service light comes on. I shut the car off and restart light goes away. I have had several times when the front brakes and the rear don't and spin out. can anyone help me with this problem.
Old Oct 16, 2013 | 01:18 PM
Kevova's Avatar
Kevova
ABS light on means DTC is set you need find out what it is. ABS maybe disabled when warning light is on.
Old Oct 16, 2013 | 09:58 PM
93Rubie's Avatar
93Rubie
Your brake fluid is low, I've ran into this problem. In between the lines is NOT good enough. Has to be topped off at MAX. and you'll be fine. NEVER light a red brake light just the Service ABS/ASR lights. Code sets for low brake fluid. Top it off and it'll be fine.
To abs help
