86 digital dash
Old Oct 17, 2013 | 06:08 PM
86 pace car's Avatar
86 pace car
Default 86 digital dash
I just had my 86 digital dash repaired on my 86 auto and in the tach panel there is a dwith a o around it maybe a overdrive signal is that suppose to be there also there is a arrow with a upshift symbol is that suppose to be there thanks
Old Oct 17, 2013 | 06:16 PM
85corvettec4's Avatar
85corvettec4
over drive is only on manuals i thought it was for the "over-drive" on the shift console, but that doesnt cause mine to light up
Old Oct 17, 2013 | 08:58 PM
hcbph's Avatar
hcbph
Default Symbols
I have an 86 former 4+3 now with a 5 speed.
On the information panel, when I shift into 2d gear or above, there's the letter D inside a letter O that comes on.
On the tach side of the instrument panel, there is a upshift symbol that comes on when you get around 2K rpm's and above till you sift to the next gear or the rpms drop.
That's all I can tell you about it.
Old Oct 17, 2013 | 09:09 PM
86 pace car
Thanks but mine is an automatic should those lights be on?
Old Oct 18, 2013 | 03:15 AM
Cliff Harris's Avatar
Cliff Harris
An automatic should have an upward pointing arrow in the upper left corner of the tach window. Underneath it says UPSHIFT FOR BEST ECONOMY.
That light will come on if you go over 40 MPH while the trans is in Drive for some amount of time I don't know offhand. The idea is to get you to shift into OD.
Old Oct 18, 2013 | 05:08 AM
hooked073's Avatar
hooked073
check your owners manual. but my 88 auto has an arrow when it wants you to up shift Iv never seen a OS light in there
Old Oct 18, 2013 | 02:23 PM
86 pace car
Does your 86 automatic have the d with the o symbol on all the time
Old Oct 18, 2013 | 09:37 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
My 86e AT has the up-shift light which illuminates when in 3rd gear for more than 60 secs approx.
No D/O light is there, I've dismantled the cluster and can confirm that.
Old Oct 18, 2013 | 09:51 PM
leesvet's Avatar
leesvet
They just rebuilt it with the 4+3 cluster LED instead of the auto. Just the wrong display for that car,. it won't be a problem, it just won't look quite right.
Auto have the UP arrow
sticks have the OD symbol.
Same function, different display for different trans.
Old Oct 20, 2013 | 09:12 AM
chris1's Avatar
chris1
I believe 86's have it in the Driver's Information Center (DIC) center console like mine does. In 87 is when it moved to the tach and speedo cluster......
To 86 digital dash
