need help
Old Oct 17, 2013 | 08:49 PM
dramarcus's Avatar
dramarcus
Default need help
ok so i was havin a lack of power and i knew before that my tranny was bad but now i have a new tranny in my vette and there still that lack of power. like today i felt like the car was gonna shut off, my exhaust is no where near as loud as before and my motor sounds like its running under water or misfiring. i was thinking maybe bad gas or my fuel injectors or bad.....what u guys think[/SIZE]
Old Oct 17, 2013 | 08:55 PM
DanielRicany's Avatar
DanielRicany
There are so many possibilities. If you have never worked on a car before, like diagnostic work, not just DIY stuff, the answers you receive here will probably be pretty useless. You should start with a basic spark and fuel diagnosis, and test compression as well. Then I would start testing things that can affect air/fuel ratio.
If you have never done this stuff before, I suggest just bringing it to the shop.
Old Oct 17, 2013 | 09:07 PM
91tpiman's Avatar
91tpiman
Year, make model?
Old Oct 17, 2013 | 09:14 PM
dramarcus's Avatar
dramarcus
1988 c4
Old Oct 17, 2013 | 09:22 PM
dramarcus's Avatar
dramarcus
i have a 1988 c4 corvette with the 350 ls1
Old Oct 17, 2013 | 09:29 PM
DanielRicany
You swapped an LS1 into it?
Old Oct 17, 2013 | 09:30 PM
DanielRicany
If that's the case you should be posting this thread in the C5 forum as well.
Old Oct 17, 2013 | 09:43 PM
S S0DEN's Avatar
S S0DEN
350 ls1?
Old Oct 17, 2013 | 09:44 PM
dramarcus's Avatar
dramarcus
typo
Old Oct 17, 2013 | 10:15 PM
jay1055's Avatar
jay1055
Plugged cat?
Old Oct 17, 2013 | 10:27 PM
DanielRicany
Originally Posted by jay1055
Plugged cat?
I thought this too after I re read it and saw the part about the exhaust tone being quieter, but was too lazy to respond at the time. lol
Good place to check though, unbolt your exhaust from the manifold, and take out the y pipe, then take it for a ride. If your power comes back somewhat then you found your problem. Had a similiar problem like this on my friend's 86 Z28.
If you get a check engine light just reset it.
Old Oct 17, 2013 | 10:56 PM
91tpiman's Avatar
91tpiman
Exhaust becoming quieter is a sure sign of the air/fuel mix going leaner. Unplug your MAF sensor and see if runs different or better. I would be willing to bet this is either MAF sensor or Fuel injectors. You should test each one of your injectors with a multimeter. Test for ohms.
Old Oct 18, 2013 | 01:04 AM
dramarcus's Avatar
dramarcus
ok guy im really thank full for all the help, a few things i just notice when i was out side fooling around with the car....one of my spark plugs had a hole burn in it so the spark was shooting out the side of the wire! dont know if this would cause that much loss in power.
Old Oct 18, 2013 | 07:04 AM
DanielRicany
Yes, It Would.
Old Oct 18, 2013 | 07:27 AM
ricasso's Avatar
ricasso
Have you checked for codes yet?
Old Oct 18, 2013 | 08:48 AM
dramarcus's Avatar
dramarcus
@ ricasso no i havent yet but that was part of my plan today thank bud
Old Oct 18, 2013 | 12:47 PM
Kevova's Avatar
Kevova
Raw fuel kills cat.conv. quick, the "honey comb" type converters can be restricted in a short time from unburned fuel. When the spark jumps out of wire to ground, the fuel sprayed by injector passes unburned into exhaust. If it is up stream of O2 sensor, O2 will send rich signal to ecm which in turn reduces fuel to engine. You need to deal with spark plug and wire(s) soon as you can. I would suggest check converter after that,
To need help
