Stumped...
Old Oct 19, 2013 | 07:49 PM
S S0DEN's Avatar
S S0DEN
Default Stumped...
1988 L98 4+3 Trans
Issue: When I depress the clutch or in N, my RPM's clime to 13-14 but one you release the clutch they return to normal.
If you have the clutch depressed, say at a stop sign the car will idle at 13 to 14. If you hit the gas real quick, the RPM's will return to normal every single time.
I have checked and adjusted the TPS and IAC on the throttle body as described in this forum using my voltage tester ect. The idle seemed better for a day or so. My TPS was reading .59 prior to me adjusting it back to .54 but I am still having the same issue.
I have also replaced the plugs, wires, cap, rotor - checked for vacuum leaks on the intake, plenum, throttle body and all the lines in the engine bay.
I am starting to wonder if the stock throttle body is sticking on me, has anyone else had this issue before?
I have no engine codes either.
Old Oct 19, 2013 | 08:24 PM
Benny42's Avatar
Benny42
Sticking throttle body is very common. The throttle shaft wears and binds in high
vacuum condition, but feels normal with the engine off when you are working on it.
I think the stick cars are more prone to it but the autos do it too. I adapted a '94 LT1
throttle body to mine, but looking back, an aftermarket model would likely be as cheap
and a lot less work. I've had 3 TPI cars and an LT1 car with this issue.
Old Oct 19, 2013 | 08:36 PM
383vett's Avatar
383vett
Most likely the throttle shaft is worn causing the throttle blades to hang up slighly open. Try cleaning the blades (inside and out) and the throttle body area with throttle body cleaner. Sometimes that will clean out the gunk that is holding the throttle body open.
Old Oct 19, 2013 | 08:45 PM
S S0DEN's Avatar
S S0DEN
I think I will take the TB off and clean it up. I am juggling a LS swap or a Stroker after tax season - So I want to wait to purchase a new TB till I know what I am building. If I do a 383, I will prob use the TPIS Intake setup and replace the TPI.
Old Oct 20, 2013 | 12:41 AM
Cliff Harris's Avatar
Cliff Harris
Is there a vacuum switch on the clutch pedal for the cruise control?
Just a guess... I have an automatic trans.
Old Oct 20, 2013 | 01:18 AM
DanielRicany's Avatar
DanielRicany
Yeah my car needs a new throttle body too. I was looking around and they don't seem to have a stock one online that I can find. I'm looking to spend like $150, if I have to pay $300 I'll just go with a 52 or 58mm.
Old Oct 20, 2013 | 01:19 AM
S S0DEN's Avatar
S S0DEN
There was, I removed the cruise control to include the switch on the pedal and all vacuum lines, servo, and linkage on the TB.
Old Oct 20, 2013 | 03:17 AM
vetteoz's Avatar
vetteoz
I'm looking to spend like $150,.
The going price for a rebuilt stock TB bored to 52mm
http://www.ebay.com/itm/TPI-52mm-bored-port-throttle-body-85-92-Z28-TA-Corvette-/230426189214?pt=Motors_Car_Truck_Parts_Accessories&hash=item35a6789d9e&vxp=mtr
Old Oct 20, 2013 | 07:17 AM
HlhnEast's Avatar
HlhnEast
My car does about the same thing. Next time you drive and are experiencing the high idle, check and see without blipping the throttle if it settles back to normal. Watch the speedo next time and see if it does settle after about 2-3 seconds at a stop. If the idle drop corresponds with the speedo zeroing out I think the IAC is reacting to the info the ECM is receiving and I am not sure what can be done to stop it.
I cleaned my old TB in the hopes it would clear the high idle. I also bought one of the remanned TBs in the link above and the car still has the slow to return idle. I still think it has to do with the IAC or the input to it.
I will be watching this thread for a solution and if I find one I will post it up.
Good luck!
Old Oct 20, 2013 | 09:10 AM
C409's Avatar
C409
.......... Try lubing the throttle body shafts with a Silicone or Teflon based spray lube ... about every six months or so ........
Old Oct 20, 2013 | 04:15 PM
S S0DEN's Avatar
S S0DEN
I took mine apart, separated the blades from the throttle shaft and cleaned them up. Iwill lube it up with heat proof grease and see if it solves the issue.
To Stumped...
