Looking for experience with Braille Batteries?
Yours was maybe a very general question that got just "general" responses. I wouldn't have one but I've never considered one either.
I just bought a Sears Advanced Gold AGM Group 34 (cheaper than their Platinum series) for $148
http://www.sears.com/diehard-advance...a=02850734000P
http://www.dekabatteries.com/assets/base/0278.pdf
Braille is all right here:
http://www.braillebattery.com/index.php/batteries/
The conversion from Braille to Deka "might" be these:
http://www.iwsti.com/forums/2524898-post1.html
If you are looking for a lightweight, longer lasting battery, I recommend their GU1R lithium battery. It is 6.6 pounds and has V8 starting power. I replaced the 55 pound Group 49 lead battery in my BMW 540i 6-speed (daily driver) with this battery at the beginning of summer here in hot Florida, so I've got 6 months on it already. It started the car more quickly and runs better, which is one of the benefits of lithium since it runs a higher, cleaner voltage. I have had the car sit for 2 weeks while out of town (has security system) and had no problem starting when I got back. Now, being lower capacity (which any lightweight battery will have), if it was going to sit for more than 2 weeks, I'd put the 2 amp lithium charger on the car. (combo for battery & charger) I recently talked to a factory race team who had a Braille lithium battery, new in box, that was their "spare" battery and was sitting in their parts cabinet for 2 years. They checked the voltage and was still at 13.5 volts! So, it can be an added benefit if you plan to store the car & don't want to put a charger on it (or can't), you can either disconnect the battery at the positive terminal or install a power disconnect switch, remove any drain from the battery, come back a year later, flip the switch and fire it up. http://www.braillebattery.com/index....ies/gu1r_combo
My buddy, Dan Binks (crew chief at Corvette Racing in the ALMS series), is a big advocate for Braille lithium. He told me he used to go through over a dozen AGM/lead batteries in the team cars each season and just finished their 3rd season with the same Braille lithium batteries. They were recently tested and were still within spec of what they were brand new nearly 3 years ago. It is also in the new C7R, then again, they do use the ML30C battery at $2k each, but have never had a failure in 3 years of racing in those cars.
So, there are some "real world" experiences that I hope help. While there are plenty of options and depending on what you are looking to do with the car and budget, it may or may not be the best option.
