Ecm prom code?
Old Oct 22, 2013 | 01:13 AM
Bob1985z51's Avatar
Bob1985z51
Default Ecm prom code?
Hey guys I'm having some custom work done on my prom chip and the guy doing it needs a 4 letter prom code and I can't seem to find it anywhere, so far I've only found 3266 and referenced that online to find "hlp" no four letter combos, I hope to send it out tomorrow morning but I can't find this code anywhere!
By the way I have an 85 corvette 4 speed car if that helps any. Thanks ya'll
Old Oct 22, 2013 | 01:54 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I bummed. All the links saved when I was investigating my prom number are gone.
efitune.org was the best for crossreffeing
Old Oct 22, 2013 | 01:57 AM
Bob1985z51's Avatar
Bob1985z51
I've been looking for hours now with no luck at all, what does the prom code represent?
Old Oct 22, 2013 | 02:46 AM
Bob1985z51's Avatar
Bob1985z51
It's a forum I have to fill out for all the custom tunes he does, so it covers from 85 and later. it's ed wright at fast chip. Thanks! I was really stressing over not finding that code anywhere!
Old Oct 22, 2013 | 03:33 AM
Cliff Harris's Avatar
Cliff Harris
The BCC (BroadCast Code) is on a silver label on the EPROM in the ECM:
There are different broadcast codes for the year, auto vs. manual trans and rear end ratio.
Yours will probably be a 3 letter code. They went to 4 letter BCCs around '88 or so.
Old Oct 22, 2013 | 10:42 AM
Snakecharmer383's Avatar
Snakecharmer383
Let me know how things turn out, I was thinking of sending him mine next spring so see if he can help my car out. I hear he is really good.
Old Oct 22, 2013 | 11:35 AM
MrWillys's Avatar
MrWillys
Take your pick:
http://chevythunder.com/prom_bcc_1985.htm
The 3266 would be BCC "HLP"
Old Oct 22, 2013 | 01:01 PM
WVZR-1's Avatar
WVZR-1
There was actually 2 HLP ID's in '85 I believe. 3266 is one choice and 2297 the other. One was a calibration for both FED & CA the other a FED only and if you scanned them for an ID you would get different results.
The 3266 is I believe the most recent for one of several through the production and service changes.
If you wanted to actually ID your present PROM you could have it scanned at the ALDL and check your results. If it's a modified PROM I don't know. You can use this and enter a VIN to maybe confirm your ID or see the possible options. When this works it's very good information. There will generally be TSB's available and accessible if there's been changes. How current is it? I don't know any longer. The TIS application is quite old. I don't know that the CVN works any longer. I used a random '85 MT VIN and the results were all what I would have expected.
https://tis2web.service.gm.com/tis2web/
Old Oct 22, 2013 | 02:42 PM
Bob1985z51's Avatar
Bob1985z51
Thanks guys!
To Ecm prom code?
