Outside Air Temp Sensor Location?
Old Jul 5, 2002 | 04:06 PM
ronsvet's Avatar
ronsvet
Default Outside Air Temp Sensor Location?
Anyone know where the OAT sensor is on a late model C4. It seems like every time I thoroughly was my C4, the OAT stops at the last temp reading for about a week. Any thoughts?
Old Jul 5, 2002 | 04:09 PM
RichS's Avatar
RichS
Default Re: Outside Air Temp Sensor Location? (ronsvet)
If you look into where the air enters the nose. It's on the left hand side. It's a small plastic peice. It almost looks like one of the deer whistle things.
Old Jul 5, 2002 | 04:14 PM
ronsvet's Avatar
ronsvet
Default Re: Outside Air Temp Sensor Location? (RichS)
Thanks Rich, I'll take a look this evening and see if I can determine why it likes to stop working.
Ron
Old Jul 6, 2002 | 11:52 AM
dlmeyers's Avatar
dlmeyers
The sensors are pretty cheap. Had to buy one for my 90 and pretty sure they are under $20, even list from GM. 2 wire connector, (the 90 is in the center area under the bumper-follow the air. It may be connected to a couple of wires, blk and LT Grn/blk.) The LT Gren/Blk wire should have 5 volts (if wire colors same as 90)
The service manual will list a chart, you note outside air temp, and chart will tell what resistance should be across the resister. (Check around section 1C1-11 if you have the service manual).
Could just be covered by dirt and road gunk.
Keep the greasy side down.
dlmeyers 90 coupe zf6 3 speed shocks
Old Jul 6, 2002 | 11:58 AM
ronsvet's Avatar
ronsvet
Default Re: Outside Air Temp Sensor Location? (dlmeyers)
Thanks DKmyers. After reading your response along with the first response, I've determined that the sensor was completely gunked-up and hardly detectable. I'll go for the replacement. It dos'nt look to difficult to pull and replace.
Thanks again,
Ron
To Outside Air Temp Sensor Location?
