85 security
Old Jul 5, 2002 | 05:21 PM
Bobbyg75's Avatar
Bobbyg75
Default 85 security
My alarm went off when my back window was shattered by some bastard. I did not shut it off since by the time I heard it and got to the car the alarm had shutoff by itself. Now the security light does not blink nor does my horn work. The car does start. Tried working the key lock with no luck and disconnected the battery for 5 minutes with no luck.
When should the security light come on and how do I reset the system?
Old Jul 5, 2002 | 05:31 PM
85vetteguy's Avatar
85vetteguy
Default Re: 85 security (Bobbyg75)
Check the fuse behind the DIC in the center of the dash. I bet it is blown.
Old Jul 5, 2002 | 05:49 PM
Bobbyg75's Avatar
Bobbyg75
Default Re: 85 security (85vetteguy)
Thanks - whats the DIC? Do I need to remove any panels for access?
Old Jul 5, 2002 | 08:07 PM
85vetteguy's Avatar
85vetteguy
DIC = Digital information Center. Idiot lights. You need to remove the bezel in the middle of the dash and then remove the idiot light cluster(4 bolts, I think), behind it you will find a fuse and the horn relay. I'm betting the fuse is blown. It only takes a minute. Let me know if you need more info or how it turns out. Guy
Old Jul 6, 2002 | 01:05 AM
MrNuke's Avatar
MrNuke
That crap of an 'alarm' was the first thing I 'fixed' in my vette. Was going off all the time and not letting me start the car for minutes.. Soo glad I killed it. ;-)
Old Jul 6, 2002 | 05:39 PM
Bobbyg75's Avatar
Bobbyg75
Found the fuse and it was blown, however, the security system still does not arm. What next?
Old Jul 6, 2002 | 05:53 PM
Bobbyg75's Avatar
Bobbyg75
Security system works! But....light does not go on or flash on exit. Bulb?
Old Jul 6, 2002 | 06:09 PM
85vetteguy's Avatar
85vetteguy
Sounds like bulb. Does horn work ok?
Old Jul 7, 2002 | 08:43 PM
Bobbyg75's Avatar
Bobbyg75
All works! Thanks for your help. What a goofy place to pu the horn fuse!
I've found that this forum is better than any manual.
Old Jul 8, 2002 | 03:53 PM
85vetteguy's Avatar
85vetteguy
They do not make repairing these cars easy. Glad it is allright now. Did you get the back window fixed? I know that was not cheap! Guy
Old Jul 8, 2002 | 11:11 PM
Bobbyg75's Avatar
Bobbyg75
Got back window replaced under my window insurance - 100% coverage. It happened a couple days prior to Memorial Day week-end and I was fortunate that after calling several window companies Glass Doctor was able to find a window and installed it the next day. So, I had the vette for the week-end.
To 85 security
