Coolant flow control valve plugged
We pulled out the coolant flow control valve and found it was plugged with crud, but the rest of the cooling system is clean. Has anyone had a similar problem that can give us advice? Is it possible to flush only the heater core of any crud in there? We ordered a new valve and will compare the existing one with a new one. Right now it is sitting in the garage partially dismantled as a "work in progress"
Debbi is the second owner of this low mileage C4 Arizona car (60K) - now in BC, Canada. I doubt the heater was ever used in Az.
Hey ragtop,We couldn't find a new coolant control valve locally, but we solved the problem and will do a complete flush next.
We flushed and back-flushed the heater core by disconnecting the inlet hose at the control valve and disconnecting the outlet hose from the radiator surge tank. We temporarily attached garden hose quick coupler hardware and were able to easily connect a charged hose and a drain hose. We flushed, then back flushed a dozen times using low pressure H2O. The quick couplers made the process easier.
We flushed a lot of crud from the heater core. Also cleaned out the control valve with some "iron out" and then tested it. The heater works like new now.
This has been a frustration that qualified professionals couldn't fix. Sometimes it just takes determination to git'er done right.
PS - the coolant control valve restricts flow to a 1/4 inch opening inside. I need to learn more about it's purpose and where to find a new one.
Thanks for your interest.
Here is a link for the valve:
http://www.rockauto.com/catalog/x,ca...,parttype,6860
The FSM says for INSUFFICENT HEATING to:
Get car to operating temp. Check both upper and lower hose. Upper hose should be cooler. If both hot, check for restrictions in heater core and related hoses and pipes.
The hoses to/from the heater core run under the coolant surge tank that is mounted on the passenger side. You should see what looks like a black plastic "hose coupler" secured with two hose clamps on the heater core inlet hose. THIS IS actually the control valve. We loosened the surge tank from it's mount so we could get better access and see what we were doing. We also remove a cover behind/below the surge tank so we could see if blend-door was working. (the blend-door opens/closes when you operate the heater with dash controls). The heater core outlet hose runs from the core to the BOTTOM of the surge tank.
Note that the control valve has an arrow to show the direction of flow.
You can block the flow just BEFORE the valve by crimping the hose with padded needle-nose vise grip if you don't have a hose crimp tool.
FYI - the control valve is GM part #10157988. Google the part # and you should be able to find out what it looks like before you start.
I hope this is of help to others here.
Cheers,
I was also looking at the diagram in the FSM. Do the in/out heater hoses from the water pump both go to the coolant surge tank. I thought one actually went to the firewall, but after looking close at the book it seems both interact with the coolant tank. I am currently in Saudi and do not have access to my Vette in Vegas. The FSM is not as good as I expected, but after spending hours with it, it will probably get better
When we loosened the surge tank we also temporarily unplugged a wire to a sensor on the surge tank. This is necessary to move the tank enough to get access to the core outlet hose and the blend-door cover and fan motor to check that. The core outlet hose has a 180 degree bend (horse shoe) at the bottom of the surge tank.
I was the extra set of hands and my son actually did the work. We fitted misc. garden hose fittings we had on hand to rig the garden house quick couplers when we did the flush. We were careful not to use full pressure. Only open the valve on the garden hose 1/2 to 1 turn so you use low water pressure and it'll work fine.
On your diagram it is in the hose that starts low on the WP and is the higher hose on the left. The valve is approx. where the two vertical lines are on that hose
Good luck
