manually adjusting fx3 for track?
Old Oct 23, 2013 | 08:24 AM
rithsleeper's Avatar
rithsleeper
Default manually adjusting fx3 for track?
My fx3 system is not working and a lot of the gears on top are busted up. However I can manually adjust them. The belsteins are in good shape but having everything repaired would be almost as much money as a new set of konis... the fx3 would need reprogramming anyway because I hage swaped to z07 springs and sways.
Does anyone have a procedure for adjusting them or should I be moving to konis? Full stiff is way too bouncy and hops on bumps and getting all 4 adjusted less would be tough because of the small adjustement angle of the gears and no "clicks" to guide me.
