atc removel.
Old Oct 25, 2013 | 04:13 PM
dustyjoe57's Avatar
dustyjoe57
Default atc removel.
recently purchased re manufactured atc unit. Am i missing location of hidden screws? removed all I could see from radio bezel and cluster. still will not budge on left side of atc/radio bezel where tach is.
need help
Old Oct 25, 2013 | 09:58 PM
vetteoz's Avatar
vetteoz
The year model helps ..................
What is a atc?
Old Oct 26, 2013 | 03:17 AM
Cliff Harris's Avatar
Cliff Harris
ATC = Automatic Temperature Control? Just a guess...
If it's a '84 - '89 dashboard there is a screw in the side of the center bezel near the top.
Old Oct 26, 2013 | 06:18 AM
dustyjoe57's Avatar
dustyjoe57
Default atc bezel and unit removal
1989 base coupe with climate control. Having difficulty locating screws to remove bezel. Do I need to remove gauge cluster bezel as well?
Old Oct 27, 2013 | 01:21 AM
Cliff Harris
The gauge cluster bezel sits on top of the center cluster bezel. You can take out all the screws for the gauge cluster bezel and move it far enough to "unhook" it from the center cluster bezel.
The center bezel has 5 screws. 2 at the bottom on each side of the HVAC control panel. Two at the top right. One at the top left that goes in sideways. There are two screws that go through the gauge cluster bezel that correspond to the screws on the top right.
To atc removel.
