1985 corvette shifting issues
Old Oct 27, 2013 | 09:44 PM
Jig A Low's Avatar
Jig A Low
Default 1985 corvette shifting issues
hey guys,
I just got back from picking up my "new to me" coupe, it has 44,000 original miles on it and the interior reflects it. mechanically it needs some maintenance type stuff, mostly tune up related. I do have one issue that I'm hoping you can help me with.
average driving--- the car shifts through the gear pretty fast which tends to bog it down alot. it also "hits" pretty hard with every shift but worse going from second to third. I've tried the TV cable adjustment which didn't help much. I'm also having an issue when cruising at 40 or 45 and slowing down some (not stopping) like going around a corner, it doesn't seem like the overdrive is dis-engaging and the motor acts like it want's to stall out, really chugs bad until I really get into it then it downshifts and smothes out. the speedo works fine to.
I read somewhere that there is something in the valve body that can cause some or all of these issue, is there any truth to this??
thanks guys.
Old Oct 28, 2013 | 02:59 AM
Cliff Harris's Avatar
Cliff Harris
Keep the trans in Drive if you're going under 50 MPH.
See how that works for you and get back if it doesn't resolve your issue.
Old Oct 28, 2013 | 06:50 AM
Jig A Low's Avatar
Jig A Low
thanks, I tried that on the way home with it, it helps with the downshifting thing obviously because it never engages, it doens't do anything for the rapid or hard shifting though.
Old Nov 2, 2013 | 09:17 PM
oldguy'sc4's Avatar
oldguy'sc4
I have an 85 with nearly identical miles and your description of the shifting fits mine exactly. As I recall from reading some previous posts, this is pretty much the norm.
Old Nov 3, 2013 | 02:54 AM
Cliff Harris
The trans probably has a shift kit in it.
My car used to shift VERY hard from 2nd to 3rd (even at very light throttle) after I put in a shift kit. I helped that somewhat by reducing the sizes of the hole in the separator plate after I found out I used the "full race" sizes by mistake (poor instructions from the guy who supplied the kit), but it's still quite hard.
Old Nov 3, 2013 | 03:27 AM
Jig A Low's Avatar
Jig A Low
thanks guys, I've been doing some research and from all the symptoms it sounds like I'm having what they call "short spring syndrome", basically, the sping in the valve body has lost it's designed length, either from breaking (common issue) or from loosing some of it's resistance (age). either way that sounds EXACTLY like what it's doing. it's going into the transmission shop Tues. to be checked out. I'd rather pay a pro to look at it and check it out with gauges than to guess it's ok and tear it up.
To 1985 corvette shifting issues
