84 tie rods loose
It seemed odd when they had the front tires off the ground (or lift) and wiggled either tire the opposite tire wiggled the same amount. It would seem like one should wiggle some without making the opposite ture wiggle if the tie rods were loose?
Im considering just getting them changed but the rack is leaking some too.
My thinking is if I put some stop leak i n, will the bad tie rods make the seals worse anyway?
What I would like to do is try the leak stopper, and if it seems better at all then get the tie rods done.
But if the tie rods being loose would keep the stop leak from working Im wasting my time. Or get the tie rods done first and take a chance with the stop leak after,
Midas qouted 700 to replace the rack and firestone qouted 850 NOT including alignment (another $90).
I feel this work is beyond what Im comfortable with but I can tell these places are high.
So, is there any point in trying the stop leak with the tie rods loose, so I can decide what I want to do right now? Is my thinking wrong and they wont affect the seals?
As far as the snake oil goes, I wouldnt waste your time. It will swell the seals for a little while, allow them to wear out even more, then fail! h
PS You can also buy rebuild kits for your rack, for under $50. Look on utube lots of how to vids.
If you got the tie rod ends, and then later you bought a rack, you would just re-use the tie rods on the new rack since it doesn't come with them, but you would have to pay for an alignment twice that way.
If I had to do it again I'd send my rack to Turn One:
http://www.turnone-steering.com/
I talked with Turn One and they do NOT send out a box. You have to figure out how to pack it for shipping on your own.
Here's an article on rebuilding a rack (the rebuild was done by Turn One):
http://www.vetteweb.com/tech/vemp_11...d/viewall.html
