Fuel Sender ground
Old Oct 30, 2013 | 04:58 PM
CT54531's Avatar
CT54531
Default Fuel Sender ground
How - and where - do I test for a bad ground relative to my fuel sender on my 87 vette.
Old Oct 30, 2013 | 05:28 PM
playsdixie's Avatar
playsdixie
fuel pump is grounded to the unit...sender is on the unit...in your tank...I think you need to be a little more specific to your issue...
Old Oct 30, 2013 | 05:58 PM
CT54531's Avatar
CT54531
Thanks. Fuel gauge reading full all the time. I've had the unit out before and even tried cleaning the contacts but it still reads full all the time. I was told recently that a problem could arise at the C8 connector on the display connector but I thought the more common issue was at the tank end. But the three wires running into there are faded and I'm not sure what color they are - pink, green (?), brown w/stripe (?).
Old Oct 30, 2013 | 06:19 PM
playsdixie's Avatar
playsdixie
there's information on this site on how to clean it...I tried, didn't work..corvette central has nice stainless steel units with or without pumps....not hard to take out...
Old Oct 30, 2013 | 06:53 PM
vetteoz's Avatar
vetteoz
Does the gauge read high with the pump connector disconnected ?
If so you are correct , it is a ground fault on the gauge wiring , not with the sender itself
Old Oct 31, 2013 | 12:02 PM
CT54531's Avatar
CT54531
It does indeed read full disconnected. My understanding was that the default display without a fuel sender installed is to show completely full. Not to be too dense but is that consistent with what your saying? Assuming the green wire is the ground, is there any location or locations to look at first? In other words, what now?
Old Oct 31, 2013 | 02:42 PM
CT54531's Avatar
CT54531
OK. I pulled the unit out and did the ohms test. Got a high reading of 96 and at the other end it didn't get below 12 or so. Are these readings acceptable?
Also, the two ground wires meet at what looks like a spade connector on top of the housing. It is VERY rusty and immovable. Should I try to force it off (or replace) and clean that area? Thank you all for the input.
Old Oct 31, 2013 | 09:25 PM
vetteoz's Avatar
vetteoz
Looks OK
GM gauge senders are typically 0 - 90 ohms
What is the resistance on the ground side of the gauge?
Old Nov 1, 2013 | 03:25 AM
Cliff Harris's Avatar
Cliff Harris
The cluster sends 5 volts to the sender element, so there should be 5 volts on one of the connector pins (ignition on, of course).
The sender element is basically just a potentiometer. The wiper voltage should vary from zero to 5 volts as the float is moved up and down.
There is a very long "damping" time on the fuel level gauge, so it takes a while for the gauge to reflect a change in the float level (keeps the gauge from jumping up and down when the fuel sloshes around in the tank). This got me when I took my sender out of the tank. I was moving the float but the fuel gauge didn't seem to be changing. I wasn't waiting long enough.
Old Nov 1, 2013 | 11:07 AM
CT54531's Avatar
CT54531
I measured resistance from the ground wire on the orange connector to what I referred to as the "spade connector" on the top of the housing and it reads open. Infinity. That shouldn't be, right?
Please bear with me on this. I'm getting better and more comfortable about electricity and measurements but still lack some confidence in what I'm doing. So... what I did - is that what you were asking?
What about the ground wire that goes from the "spade connector" to the white plastic thing (don't even know what it's called) into which the power wires run. Should that/can that be tested?
Thanks.
Old Nov 1, 2013 | 11:14 AM
CT54531's Avatar
CT54531
"The cluster sends 5 volts to the sender element, so there should be 5 volts on one of the connector pins (ignition on, of course).
The sender element is basically just a potentiometer. The wiper voltage should vary from zero to 5 volts as the float is moved up and down."
So it's okay to test these things with the unit out of the tank? I had this concern that powering it up might get the pump sucking air or something. Hope that's not too stupid. As I said in the previous post, I'm making a concerted effort to learn about these things but I'm not there yet.
Old Nov 2, 2013 | 12:36 AM
Cliff Harris
Sure. The fuel pump is turned on for 2 seconds when you first turn on the ignition to pressurize the fuel rails. It then shuts off so it won't run continuously if the ignition is turned on but the engine is not started. It doesn't get turned on again until the engine is cranked or running.
When I tested mine I opened the hatch so I could see the instrument panel better and then moved the float arm to see how the fuel gauge reacted. It has a delay built in to avoid the gauge jumping around when the fuel sloshes in the tank, so it takes a few seconds for the gauge to reflect what the float arm is doing.
Old Nov 2, 2013 | 12:26 PM
CT54531's Avatar
CT54531
Okay. What I'm thinking of doing is scrape/dremel the ground contacts off the housing (by that I mean the plate at the top where the inlet is), clean things up and - what? - solder the ground(s) onto clean metal? Feasible? Sensible?
Old Nov 2, 2013 | 01:26 PM
CT54531's Avatar
CT54531
Issue resolved. Just scraped as much rust off the contact as I could get to and - voila! Gauge works fine. Thank you all for the knowledge and input.
Old Nov 3, 2013 | 02:17 AM
Cliff Harris
I suggest some dielectric grease to prevent future rust issues.
Old Nov 4, 2013 | 10:26 AM
CT54531's Avatar
CT54531
Yes. I was going to ask about that. Thanks.
To Fuel Sender ground
