1995 dies while driving
Old Oct 31, 2013 | 05:05 PM
michaeljohnson's Avatar
michaeljohnson
Default 1995 dies while driving
my 95 corvette LT1 died on me last friday first it hesitated like you put it in neutral then died completly like someone turned off the key i put it in neautral while coasting and tryed to start it wanted to catch but turned off again pulled over stoped and it started.later that day on my way home it did it again on the way home but this time it didnt catch at all when cranked for 5 min. then started like normal thinking the icm was overheating i went and replaced the icm(AC delco) took it on a pretty long drive didnt miss a beat on the way to work this morning it died again with a hesitation again started right back up but felt like it was missing so i let it cool off for 5 mins. after it ran like normal all the way to work and in the afternoon i got caught in traffic temp got up to 230 didnt miss a beat the whole way home.well sorry for the long post but does anyone have any suggestions?
thanks
Old Oct 31, 2013 | 05:23 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Check the fuel pump (including the sock on the end of the pickup tube) and the fuel pressure & leak-down. If all of that is good, your ECM may be acting up.
Old Oct 31, 2013 | 05:45 PM
aminnich's Avatar
aminnich
Scan it for codes first. Both easy and free.
Old Oct 31, 2013 | 05:55 PM
michaeljohnson
i checked the fuel pressure a couple months back 43 key on let it sit for 10 mins. couldnt see any drop on gauge i was under the impression if it was fuel it would sputter then die.after it hesitates there isnt a loss of power beyond that second i will have the codes read tommorow hopefully also the car has about 120K miles the only parts ive replaced so far are the coil,plugs and icm all ac delco it has a accel opti on it from one of the previous owners
thanks for the replys
Old Oct 31, 2013 | 07:20 PM
ToniJ1960's Avatar
ToniJ1960
I had another car one time that did that. It would stall on the highway or wherever and a few minutes later it would start up and go again until it died again. It just cut off, changed the ignition module fuel filter fuel pump carb. It was the sock in the tank.
Old Nov 2, 2013 | 11:51 AM
michaeljohnson
i got a fuel pressure gauge today when i turned the key on first it went up to 10 PSI tryed again 23 then it started slowly going up a couple pounds ran it it was about 35 PSI after shut off it bled up to 43 PSI slowly when i drained the fuel off through the clear tube i could see little black particles floating in the fuel ive got a new AC delco fuel filter coming hopefully that will fix it but i replaced the fuel filter in april and tested it in may for fuel pressure at school i had perfect fuel pressure the one i took off looked to be original it had like sand/silt come out when i took it off i replaced with a duralast filter ive run it maybe 2500 miles since then
Old Nov 2, 2013 | 04:33 PM
michaeljohnson
went ahead and bought a purolator fuel filter put it on runs alot better then i went to go somewhere and the tach started bouncing around so i went home was checking it out in my driveway it was missing when i brought it up to 1500 rpm then the tach needle bounced to 1750 then 2000 rpm in rapid succession and i went around back of the car and it shut off
Old Nov 2, 2013 | 04:59 PM
michaeljohnson
i tryed the paperclip method of getting codes not sure if i did it right but i went to modual 4.1 and when i pressed the top two buttons it just showed 3 dashed lines does that mean i have no codes?
Old Nov 2, 2013 | 05:51 PM
don hall's Avatar
don hall
There is a lot more useful info than just recovering codes in
this link. so you might get acquainted:
http://www.corvettephotographs.com/c4vettes/ecm.htm
Old Nov 2, 2013 | 07:04 PM
michaeljohnson
thanks for the link so i dont have any pcm codes i was looking at other threads and most of them ended up at the opti how would i test to see if my opti is bad?
Old Nov 2, 2013 | 07:17 PM
don hall's Avatar
don hall
May be more than your needs (click on link) ...... (forget the vehicle types... they have LT1 engines using the opti):
http://www.youtube.com/watch?v=lFCja...ature=youtu.be
Old Nov 2, 2013 | 08:51 PM
michaeljohnson
i tested terminals A and D on the ICM weather pack got 11.75 V good tested term. B2.8V ac good im trying to get the optis weather pack off but it is in there ive been tryin for the last 20 minutes to get the thing off can i probe upstream?
thanks for the help guys
Old Nov 2, 2013 | 09:21 PM
michaeljohnson
thanks for the vid i followed all thier directions and tested the ones for the ICM and the dist from PCM all were good i couldnt get the dist weather pack off so i tested at the pack by the fuel rail a little up the line but all was good so what should i do now?
thanks for the help
Old Nov 3, 2013 | 03:16 AM
Cliff Harris's Avatar
Cliff Harris
The stalling you're seeing is an intermittent condition. Sometimes it's there. Sometimes it's not. You might have done all your tests when the problem is in the "not there" condition.
Intermittents are the worst kind of problems because it's so hard to get the "not OK" condition to appear. You can't troubleshoot it if it's working. Another problem is that you can't be sure you fixed it. You do something and it seems to be OK. The next day it fails.
All that said, it's very common for the ignition system on LT1s to have problems with the connectors. The pins get corroded and make poor contact. Take all the connectors apart and spray them with contact cleaner. It's also a good idea to unplug and plug them in multiple times to scrape off any corrosion and help make a good connection.
I have also heard of wires getting broken or pinched. Check them out. I have seen wires that were broken INSIDE the insulation (that usually happens from too much bending, especially around sharp corners). They looked OK, but the connection was not there.
Old Nov 3, 2013 | 10:14 AM
michaeljohnson
ok ill go out and get some contact cleaner who would sell that radioshack?well im pretty sure ive eliminated temp. as the cause since it got up to 230s and didnt cut out but the tach bouncing around is there everytime ive started it since last night(bring it to 1500 and it will bounce to 2000-2200 with no change in engine speed)ive been looking through the FSM for a tree related to that is there one you know of?
thanks
Old Nov 3, 2013 | 12:07 PM
michaeljohnson
i went to autozone,radioshack and best buy the ended up with electronics part cleaner says safe for most plasicsi coudnt find anything better at autozone and best buy only has the compressed air cans is that ok to clean up my weather packs?
Old Nov 3, 2013 | 10:22 PM
95BLKVette's Avatar
95BLKVette
How many miles on the opti?
Put it in neutral after heating up to 180f on digital coolant display and slowly raise rpms up to 3 to 4 k.
If tack starts bouncing around at high speed you should set a code 16 low res signal code and that will be opti optical sensor on the way out.
Good luck....I'm currently waiting for my warranty opti from Chandler Motorsports
To 1995 dies while driving
Old Nov 5, 2013 | 06:58 PM
michaeljohnson
im not sure on the miles ive had the car since march and it was on there when i bought it.i only brought it up to 1500 and i did jump around.it was an accel unit i took it out my WP looks to have been leaking through the weep hole the best thing i could find for the money/time ive got was a cardone new opti i put it on today and ill fire it tommorow before i put on my new WP ive seen posts good and bad on the cardones i hope ive got a good one
also when i took my opti out i noticed that theres a metal ring around the splined shaft for the water pump mines bent up what does it do?where does it go? its on the shaft coming out of the timing cover.
Old Nov 5, 2013 | 09:17 PM
VirajPatel21's Avatar
VirajPatel21
thanks
mine did that, check your fuel pump to see if there is any gunk in there and your fuel filter. I replaced both of them and baam she was back to her original glory
Old Nov 6, 2013 | 05:50 PM
michaeljohnson
started it today then it immediatly died checked all connections,wires etc. good tried again started after a 4 to 5 sec crank ran like crap and while cranking the tach is all over the place im thinking DOA opti ive gone over everything 3 times cant find anything unpluged got a good coolant temp reading(68F)all sensors pluged in
does anyone know if the new delphi opti part # CZ20003 is like the factory piece with a mitsubishi optical sensor?
