injectors
Old Nov 6, 2013 | 04:59 PM
prostreeter's Avatar
prostreeter
Default injectors
motor starts cold,after hot and turned off it won,t start till cold again, been told it is injectors, is this correct?1990 corvette
Old Nov 6, 2013 | 05:45 PM
floridamale's Avatar
floridamale
You need to get a ohm meter and check what the injectors read both hot and cold then check back with your readings
Old Nov 6, 2013 | 06:21 PM
MrWillys's Avatar
MrWillys
Do what is said above, and you"ll find one or more are bad. They're either leaking and flooding or overheating the injector driver in the ecm. Be careful not to let anyone sell you Bosch yellows as direct replacements or it will run lean.
To injectors
